Nios® II Embedded Design Suite (EDS)
Support for Embedded Development Tools, Processors (SoCs and Nios® II processor), Embedded Development Suites (EDSs), Boot and Configuration, Operating Systems, C and C++
use tse mac loopback
i want to use the loopback function of tse mac.
how could i start it?
thank you in advance!
FangQJ
Check the datasheet (http://www.altera.com/literature/ug/ug_ethernet.pdf): By just doing a search on the word "loopback", I found the relevant pages: 3-2 for hardware configuration, 4-18 and 4-19 for the procedure and 6-8 for the configuration register.
thanks Daixiwen,
it's very helpful~
because i could not use two tse mac on DE2-115 board, which i stuck at the tse mac driver of nichestack, i want to use the loopback instead.
thank you very much~
PS, any suggestion about using of two tse macs will be great~
