using ISP1362 in target mode
Hi all,
I have a cyclone4 board using isp1362
I followed USBHost tutorial in altera wiki
first result i have an error
--- Quote Start ---
isp1362-hcd isp1362-hcd: ISP1362 Host Controller
isp1362-hcd isp1362-hcd: new USB bus registered, assigned bus number 1
isp1362_hc_reset:
Clock not ready after 100ms
isp1362-hcd isp1362-hcd: can't setup
isp1362-hcd isp1362-hcd: USB bus 1 deregistered
isp1362_probe: init error, -19
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
--- Quote End ---
so i replaced return ret by return 1 in isp1362_hc_reset
result
--- Quote Start ---
isp1362_hc_reset:
isp1362-hcd isp1362-hcd: irq 6, io mem 0x08000980
isp1362_hc_start:
isp1362-hcd isp1362-hcd: ISP1362 Memory usage:
isp1362-hcd isp1362-hcd: ISTL: 2 * 256: 512 @ $0000:$0100
isp1362-hcd isp1362-hcd: INTL: 16 * ( 64+8): 1152 @ $0200
isp1362-hcd isp1362-hcd: ATL : 32 * ( 64+8): 2304 @ $0680
isp1362-hcd isp1362-hcd: USED/FREE: 3968 128
usb usb1: New USB device found, idVendor=1d6b, idProduct=0001
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: ISP1362 Host Controller
usb usb1: Manufacturer: uClinux 2.6.30 isp1362-hcd
usb usb1: SerialNumber: isp1362-hcd
usb usb1: configuration# 1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
ISP1362 Host Controller, irq 6
--- Quote End ---
but when i connect the board to pc, nothing is detect :s
I missed a step ? :(
