Hi all,
I have a cyclone4 board using isp1362 I followed USBHost tutorial in altera wiki first result i have an error --- Quote Start --- isp1362-hcd isp1362-hcd: ISP1362 Host Controller isp1362-hcd isp1362-hcd: new USB bus registered, assigned bus number 1 isp1362_hc_reset: Clock not ready after 100ms isp1362-hcd isp1362-hcd: can't setup isp1362-hcd isp1362-hcd: USB bus 1 deregistered isp1362_probe: init error, -19 Initializing USB Mass Storage driver... usbcore: registered new interface driver usb-storage --- Quote End --- so i replaced return ret by return 1 in isp1362_hc_reset result --- Quote Start --- isp1362-hcd isp1362-hcd: ISP1362 Host Controller isp1362-hcd isp1362-hcd: new USB bus registered, assigned bus number 1 isp1362_hc_reset: Clock not ready after 100ms isp1362-hcd isp1362-hcd: irq 6, io mem 0x08000980 isp1362_hc_start: isp1362-hcd isp1362-hcd: ISP1362 Memory usage: isp1362-hcd isp1362-hcd: ISTL: 2 * 256: 512 @ $0000:$0100 isp1362-hcd isp1362-hcd: INTL: 16 * ( 64+8): 1152 @ $0200 isp1362-hcd isp1362-hcd: ATL : 32 * ( 64+8): 2304 @ $0680 isp1362-hcd isp1362-hcd: USED/FREE: 3968 128 usb usb1: New USB device found, idVendor=1d6b, idProduct=0001 usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 usb usb1: Product: ISP1362 Host Controller usb usb1: Manufacturer: uClinux 2.6.30 isp1362-hcd usb usb1: SerialNumber: isp1362-hcd usb usb1: configuration# 1 chosen from 1 choice hub 1-0:1.0: USB hub found hub 1-0:1.0: 2 ports detected ISP1362 Host Controller, irq 6 Initializing USB Mass Storage driver... usbcore: registered new interface driver usb-storage --- Quote End --- but when i connect the board to pc, nothing is detect :s I missed a step ? :(Link Copied
