vendor_hwselect - error 2
[root@localhost uClinux-dist]# make vendor_hwselect SYSPTF=~/uclinux/NiosII_stratixII_2s60_standard.ptf
make ARCH=nios2 -C vendors vendor_hwselect
make[1]: Entering directory `/root/uclinux/nios2-linux/uClinux-dist/vendors'
make -C /root/uclinux/nios2-linux/uClinux-dist/vendors/Altera/nios2/. dir_v=/root/uclinux/nios2-linux/uClinux-dist/vendors/Altera/nios2/. -f /root/uclinux/nios2-linux/uClinux-dist/vendors/vendors-common.mak vendor_hwselect
make[2]: Entering directory `/root/uclinux/nios2-linux/uClinux-dist/vendors/Altera/nios2'
[ -d /root/uclinux/nios2-linux/uClinux-dist/romfs/$i ] || mkdir -p /root/uclinux/nios2-linux/uClinux-dist/romfs
make ARCH=nios2 CROSS_COMPILE=nios2-linux-uclibc- hwselect
make[3]: Entering directory `/root/uclinux/nios2-linux/uClinux-dist/vendors/Altera/nios2'
make[3]: *** No rule to make target `hwselect'. Stop.
make[3]: Leaving directory `/root/uclinux/nios2-linux/uClinux-dist/vendors/Altera/nios2'
make[2]: *** [vendor_hwselect] Error 2
make[2]: Leaving directory `/root/uclinux/nios2-linux/uClinux-dist/vendors/Altera/nios2'
make[1]: *** [vendor_hwselect] Error 2
make[1]: Leaving directory `/root/uclinux/nios2-linux/uClinux-dist/vendors'
make: *** [vendor_hwselect] Error 2
*****************************************88
I'm encountering the above error when I run the vendor_hwselect command
caN ANYONE PLEASE LET ME KNOW IF ANYONE HAD THE SAME PROBLEM
OR IF YOU THINK I MIGHT HAVE MADE FEW MISTAKES IN THE CONFIGURATION
THANK YOU
Hello, a few tips that might help:
1) Did the project compile correctly?
2) Have you tried putting the full path to the ptf file?
3) I don't know about how you installed your software, but I make the hw select as a user and not as root, and in the nios2-linux/uclinux-dist directory
4) Is the name for the PTF file correct? Do not mistake it for the project's name.
Hope it helps
Francisco
5) Have you tryed to run "make menuconfig" first of vendor_hwselect ?
6) Did you have write permission in PTF dir ?
I've re tried it with changes mentioned by you
and still it is the same error
one thing i'm not sure is ..are these errors occurring coz I have not updated the uclinux_dist patches???
<div class='quotetop'>QUOTE (dilip @ Jul 7 2009, 01:30 PM) <{post_snapback}> (index.php?act=findpost&pid=23033)</div>
--- Quote Start ---
I&#39;ve re tried it with changes mentioned by you
one thing i&#39;m not sure is ..are these errors occurring coz I have not updated the uclinux_dist patches???[/b]
--- Quote End ---
which kernel version r u using? Make sure that your linux distribution is correctly extracted and tool chain is working fine.
Good Luck...!
same error here in NEEK
Hi
I revd following errors while compiling. I am unable to figure out what is problem. My design compiled correctly.
make vendor_hwselect SYSPTF=/media/96A00F1FA00F0609/altera/temp/try1.ptf
make[1]: Entering directory `/home/elysium/uclinux/nios2-linux/uClinux-dist/vendors'
make -C /home/elysium/uclinux/nios2-linux/uClinux-dist/vendors/Altera/nios2/. dir_v=/home/elysium/uclinux/nios2-linux/uClinux-dist/vendors/Altera/nios2/. -f /home/elysium/uclinux/nios2-linux/uClinux-dist/vendors/vendors-common.mak vendor_hwselect
make[2]: Entering directory `/home/elysium/uclinux/nios2-linux/uClinux-dist/vendors/Altera/nios2'
[ -d /home/elysium/uclinux/nios2-linux/uClinux-dist/romfs/$i ] || mkdir -p /home/elysium/uclinux/nios2-linux/uClinux-dist/romfs
make ARCH=nios2 CROSS_COMPILE=nios2-linux-uclibc- -C /home/elysium/uclinux/nios2-linux/uClinux-dist/../linux-2.6 O=/home/elysium/uclinux/nios2-linux/uClinux-dist/linux-2.6.x hwselect
make[3]: Entering directory `/home/elysium/uclinux/nios2-linux/linux-2.6'
GEN /home/elysium/uclinux/nios2-linux/uClinux-dist/linux-2.6.x/Makefile
scripts/kconfig/conf -s arch/nios2/Kconfig# # configuration written to .config#
make[4]: *** No rule to make target `hwselect'. Stop.
make[3]: *** [sub-make] Error 2
make[3]: Leaving directory `/home/elysium/uclinux/nios2-linux/linux-2.6'
make[2]: Leaving directory `/home/elysium/uclinux/nios2-linux/uClinux-dist/vendors/Altera/nios2'
make[1]: Leaving directory `/home/elysium/uclinux/nios2-linux/uClinux-dist/vendors'
I think CROSS COMPILER is not nios2-linux-uclibc- hwselect. Any help?
You have to change your branch for NO MMU which is test-nios2. Default branch is now for MMU version and hwselect is working only for NO MMU version. You have to:
In nios2-linux/linux-2.6
run command:
git checkout test-nios2
and the same command in nios2-linux/uClinux-dist
Then you can use hwselect method.
