12600 Discussions
verilog example of a dual port ram with a burst capable avalon interface ??
can anybody show me the resource path or provide me a good example design in verilog having avalon interface (with beginbursttransfer and burstcount signals i.e burst supported).
Or Is there any way to create a template in quartus prime pro edition or a platfrom designer tool so that i may instantiate my User_logic into it.:)
Anil
--- Quote Start ---
Refer the below links,Which gives information for single port ram which may help.
https://www.altera.com/support/support-resources/design-examples/intellectual-property/embedded/nios-ii/exm-avalon-mm.html
https://www.altera.com/support/support-resources/design-examples/intellectual-property/embedded/nios-ii/exm-avalon-memory-slave.html
http://alterawiki.com/wiki/interfacing_to_altera_external_memory_controller_ip
Yes, you can create a template/design.
Referftp://ftp.altera.com/up/pub/altera_material/14.0/tutorials/making_qsys_components.pdf
Anand Raj Shankar
(This message was posted on behalf of Intel Corporation)
--- Quote End ---
first url link: it has a master template
second url link: it has a slave template but not burst capable
third link: out of scope.
pdf Link:
Creating a template means , In vivado, tool generates axi4-full slave top wrapper with all the logic built into it like it takes care of burst type, internal address increments (burst) and necessary response and acknowledgement handling and even a small portion of dpram under userlogic section. The pdf you provided implements a single register that too no involvement of READ signal. I am looking for a more advanced code with a burst capable.
For understanding sake , i am asking a dualport ram verilog code surrounded by a avalon interface logic. I want to study it and tag this into my platform designer and finally want to do burst read and write testing through simple DMA Controller. :(
Anil
