12455 Discussions
wahen i flash my zimage on flash memory , i can't use telnet
hi all
please , i use µclunix , when i flash the zimage in flash memory ans i desactive the JTAG UART , i can't use telnet , in my file RC , i add inetd&
--- Quote Start ---
hostname uClinux
mount -t proc proc /proc -o noexec,nosuid,nodev
mount -t sysfs sysfs /sys -o noexec,nosuid,nodev
mount -t devpts devpts /dev/pts -o noexec,nosuid
mount -t usbfs none /proc/bus/usb
mkdir /var/tmp
mkdir /var/log
mkdir /var/run
mkdir /var/lock
mkdir /var/empty
ifconfig lo 127.0.0.1
route add -net 127.0.0.0 netmask 255.0.0.0 lo# dhcpcd -p -a eth0 &
cat /etc/motd
mknoddev
ifconfig eth0 192.168.10.180
inetd&
--- Quote End ---
but when i flash my Zimage in RAM , i can use telnet withou any problem
please, if someone have an idea , or if there is other configuartion to be able to use the telnet , I realy need it
thank's
What if you
disable the JTAG UART and run from RAM?
enable the JTAG UART and run from flash?
I have the same problem,
I write sof in EPCS and program in CFI
--- Quote Start ---
sof2flash --epcs --input=<chemin>/irp.sof --output=fpga_sof.flash
elf2flash --base=0x02800000 --end=0x02FFFFFF --reset=0x02800000 --input=zImage --output=uc_flash.flash --boot=<chemin>/Altera/nios2eds/components/altera_nios2/boot_loader_cfi.srec
nios2-flash-programmer --epcs --base=0x03001800 fpga_sof.flash
nios2-flash-programmer --base=0x02800000 uc_flash.flash
--- Quote End ---
uc_flash.flash = 6MBytes, so i changed Processor type and features--> Link address offset for booting from 0x00500000 to 0x01555555 (2/3 of my 32M sdram)
I also changed rc file
--- Quote Start ---
hostname uClinux
mkdir /var/tmp
mkdir /var/log
mkdir /var/run
mkdir /var/lock
mkdir /var/empty
cat /etc/motd
mknoddev
ifconfig eth0 192.168.10.170
inetd&
--- Quote End ---
After reboot, ping 192.168.10.170 work but not telnet
(I disabled the JTAG UART and i have 2 uart in sopc used for my application)
Thanks for help
if you disable "Support for console on Altera JTAG UART" only it dosen't work
but if you add Bypass output when no connection it work for me :)
yessss it work thanks hayder and ykozlov (http://www.alteraforum.com/forum/member.php?u=26158)
