12603 Discussions
what's wrong with the Flash programmer?
hello all,
QII4.2,Nios 1.1
I encounted a strange problem when I use the flash programmer frome Nios IDE.the console show:
# ! /bin/sh# # This file was automatically generated by the Nios II IDE Flash Programmer.# # It will be overwritten when the flash programmer options change.#
cd D:/Nios/flashprogrammer/software/s251_flashprogrammer/Debug
# Creating .flash file for the FPGA configuration
$SOPC_KIT_NIOS2/bin/sof2flash --flash=U4 --offset=0x00600000 --input=D:/Nios/fla
shprogrammer/s25_lock.sof --output=s25_lock.flash
Info: *******************************************************************
Info: Running Quartus II Convert_programming_file
Info: Command: quartus_cpf --no_banner --convert D:/Nios/flashprogrammer/s25_loc
k.sof s25_lock.rbf
Info: Quartus II Convert_programming_file was successful. 0 errors, 0 warnings
Info: Processing ended: Fri Mar 18 09:35:55 2005
Info: Elapsed time: 00:00:01
WARNING: Default charset GBK not supported, using ISO-8859-1 instead
# Programming flash with the FPGA configuration
$SOPC_KIT_NIOS2/bin/nios2-flash-programmer --input=s25_lock.flash --sof=d:/nios/
flashprogrammer/my_1s251_board/system/my_1s251_board.sof --cable='ByteBlasterII
[LPT1]' --base=0x00800000
Mar 18, 2005 9:36:00 AM - (??) nios2-flash-programmer: Launching Quartus Program
mer to download:
d:/nios/flashprogrammer/my_1s251_board/system/my_1s251_board.sof
Pre-Reading 964KBytes of data from U4:
********************* (43.875 sec).
Erasing 16 Sectors:
********************* (10.656 sec).
Writing 1024KBytes :
********************* (66.719 sec).
Verifying 1024KBytes of data:
********************* (42.594 sec).
Mar 18, 2005 9:39:18 AM - (??) nios2-flash-programmer: Success. Verified 1024Kby
tes written to U4.
Mar 18, 2005 9:39:18 AM - (??) nios2-flash-programmer: Flash programming complet
# Creating .flash file for the project
$SOPC_KIT_NIOS2/bin/elf2flash --flash=U4 --base=0x00000000 --end=0x800000 --rese
t=0x0 --input=s251_flashprogrammer.elf --output=ext_flash.flash --boot=$SOPC_KIT
_NIOS2/components/altera_nios2/boot_loader_cfi.srec
# Programming flash with the project
$SOPC_KIT_NIOS2/bin/nios2-flash-programmer --input=ext_flash.flash --sof=__NO_SO
F_PLEASE__ --cable='ByteBlasterII [LPT1]' --base=0x00800000
Mar 18, 2005 9:39:19 AM - (??) nios2-flash-programmer: SOF-download skipped.
Pre-Reading 0KBytes of data from U4:
*********************Mar 18, 2005 9:39:29 AM - (??) nios2-flash-programmer:
Flash file is too large to fit in flash memory
the error when download application is:Flash file is too large to fit in flash memory
why? before download ext_flash.flash ,the file is 200kbyte
but after that ext_flash.flash is only 1kbyte
when run all is ok.
thank you
