12600 Discussions
where can i get a SGMII design example for reference?
HI, i am new here, here can i get a design reference for the SGMII, i ma using a Arria 10 here.
--- Quote Start ---
--- Quote End ---
I saw a similar application in rocket board, but this is for Cyclone V, not for Arria 10 yet....
here is the example, or you need this for your own reference for Arria 10? Might ned ot do quite some manual migration too..
http://rocketboards.org/foswiki/view/projects/cyclonevsgmiiexampledesign
do we have any example design for Arria 10?
i no seen this in the web yet... probably sooner may have it in rocketboards soon.. lol////
what are the potential effort needed to implement this in Arria 10?
i believe some effort required, starting from the hardware quartus migration, then you may need to migrate those driver setting from device tree from 14.0 to current 15.0, not sure if it may get caught in some incompatibility issues. infact the kernel provided is for 14.0 only.
This is only for normal usage, is this design example is covering ieee 1588 standard? i mean hps area, not tse.
--- Quote Start ---
--- Quote End ---
As far as i tried to search around the web, i never seen any design example for ieee 1588 with hps emac... but if you are saying for tse, i saw having several versions. even come with 1588v2. Well if you are interested, you may start to do this completely from linux driver onward :D
He is right.. no such design reference so far for this area.....
