12453 Discussions
where could I find the nios-linux-20120621.tar , the Wiki link is out of work
wget http://sopc.et.ntust.edu.tw/pub/linux/nios2-linux-20100621.tari cannot download this file ,are there any other sources???thanksfrank
--- Quote Start ---
--- Quote End ---
I am looking for this file too, can't locate. The closest I find is http://www.uclinux.org/pub/uclinux/dist/uclinux-dist-20100628.tar.bz2, but don't know whats the difference between 2010/06/21 and 2010/06/28 images.
if you choose to use this description ,you should patch nios2 drivers ,but there is no patch available
i used this:
--- Quote Start ---
#get the initial git files - This gets a bunch of tar files so they are not too big...
wget ftp://ftp.altera.com/outgoing/nios2-linux/20120802/* .
# This should download the following
# ftp://ftp.altera.com/outgoing/nios2-linux/20120802/files.md5sum
# ftp://ftp.altera.com/outgoing/nios2-linux/20120802/nios2-linux-3c120_default-20120802.tgz
# ftp://ftp.altera.com/outgoing/nios2-linux/20120802/nios2-linux-base-20120802.tgz
# ftp://ftp.altera.com/outgoing/nios2-linux/20120802/nios2-linux-binutils-20120802.tgz
# ftp://ftp.altera.com/outgoing/nios2-linux/20120802/nios2-linux-boards-20120802.tgz
# ftp://ftp.altera.com/outgoing/nios2-linux/20120802/nios2-linux-elf2flt-20120802.tgz
# ftp://ftp.altera.com/outgoing/nios2-linux/20120802/nios2-linux-gcc3-20120802.tgz
# ftp://ftp.altera.com/outgoing/nios2-linux/20120802/nios2-linux-glibc-20120802.tgz
# ftp://ftp.altera.com/outgoing/nios2-linux/20120802/nios2-linux-insight-20120802.tgz
# ftp://ftp.altera.com/outgoing/nios2-linux/20120802/nios2-linux-linux-2.6-20120802.tgz
# ftp://ftp.altera.com/outgoing/nios2-linux/20120802/nios2-linux-openip-20120802.tgz
# ftp://ftp.altera.com/outgoing/nios2-linux/20120802/nios2-linux-toolchain-build-20120802.tgz
# ftp://ftp.altera.com/outgoing/nios2-linux/20120802/nios2-linux-toolchain-mmu-20120802.tgz
# ftp://ftp.altera.com/outgoing/nios2-linux/20120802/nios2-linux-tools-20120802.tgz
# ftp://ftp.altera.com/outgoing/nios2-linux/20120802/nios2-linux-u-boot-20120802.tgz
# ftp://ftp.altera.com/outgoing/nios2-linux/20120802/nios2-linux-uclibc-20120802.tgz
# ftp://ftp.altera.com/outgoing/nios2-linux/20120802/nios2-linux-uclinux-dist-20120802.tgz
# check that they are right
md5sum --check files.md5sum
# extract the files - they will extract into a directory called nios2-linux
for i in $(ls nios2-linux-*.tgz); do tar -xzvf $i;done
# For mmu-less nios2 uCLinux, download the precompiled toolchain as well
wget ftp://ftp.altera.com/outgoing/nios2-linux/nios2gcc-20080203.tar.bz2
# this extracts to nios2-linux/opt
tar -xvf nios2gcc-20080203.tar.bz2
--- Quote End ---
