Hi, All
Could anyone help me to find this pof file: cycloneIII_3c120_dev_factory_recovery.pof I want to make the c3_3c120_dev_kit to the factory default setting based on the P25-36208-03_cycloneIII_3c120_dev_user_guide.pdf, but i can not find this pof file. Pls help me !!Link Copied
If you installed the kit support files it will be in C:\altera\90\kits\cycloneIII_3c120_dev\factory_recovery
You can find the support files here (http://www.altera.com/products/devkits/altera/kit-cyc3.html), in the available documentation section.- Mark as New
thanks for your reply. Daixiwen.
I can find several sof and pof files in the factory_recovery folder, but there is no the exactly same file as the "cycloneIII_3c120_dev_factory_recovery.pof". If you have, could you send one copy to me ?- Mark as New
what files do you have? Are you sure you downloaded the right one from Altera?
The .pof file is 64MBytes... A bit too big to send.- Mark as New
Did you ever find that factory recovery file? I'm looking for it too and can't find it
what files do you have in the factory recovery folder? Did you download the kit support files from the link I gave? If you have the 9.0/9.1 versions, the .pof file should directly be there.
If you have a newer version, then you'll have a script that will reprogram the flash. The procedure is described in the user guide, chapter "Restoring the Flash Device with the Factory Settings"
