hello!
I explant my uclinux system form arm(Samsung 4510) to nios2, I need build ppp with serial port, so we need pppd, now I have a terrible problem,I find the pppd consume neraly 1.2M sdram. I can't abide it, beacause only 300kb memory is needed in the arm system. I indeed the source is same in the two plats. who can help me? Thank you for all response!Link Copied
Did your arm have shared obj? The current nios2 did not support shared obj yet.
Another question, how do you take the size of the exec obj?- Mark as New
--- Quote Start --- originally posted by hippo@Mar 8 2006, 09:15 AM did your arm have shared obj? the current nios2 did not support shared obj yet.
another question, how do you take the size of the exec obj?
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=13221)
--- quote end ---
--- Quote End --- Hi,hippo! Thanks for your repsonds, there are no mmu in the both flatforms arm and nios2, I only use the lib uClibc, I am a begginer, so I don't know share obj clearly. I get the memory size of the pppd exec through catting the /proc/meminfo content. I think the free memory's difference between before and after the pppd run is the memory size of pppd used.In addition, I find 1.2M excess memory is impropriated at the begging of ppp building.In other word, the pppd process need almost 2.4Mb memory when they attempt building ppp link with remote. After the ppp link is successful build, the excess 1.2Mb memory will be free can you tell another better mothod to caculater the memory size of the exec obj clearly? Thanks a lot.
Did you count in buffer/cache for free memory?
Use "free" command is easier than "cat /proc/meminfo", you should include buffer/cache for free memory.- Mark as New
Hi, hippo.
thank you for your help.I find the size of cache and the buffer isn't change,the only difference of the memory info before and after pppd run is freemem.the result is same by "cat /proc/meminfo" and using free command. in addition, I find all the application use more memory than arm. I am looking forward to you reply, thank you very much- Mark as New
Hi smalllight,
Let try find out what's the diff in exec, please use xxxxx-flthdr to each of them.- Mark as New
<div class='quotetop'>QUOTE </div>
--- Quote Start --- let try find out what's the diff in exec, please use xxxxx-flthdr to each of them.[/b] --- Quote End --- What dose "xxxxx-flthdr" meaning? Could you figure out in detail? Thank u in advance. BTW, what do those flags meanings? 1. elf2flt -s 16000 / elf2flt -s 8192 2. gcc -Wl (Does -W have anymore flags? ) or , pls show us how to find more information about hwo to use gcc ?- Mark as New
--- Quote Start --- What dose "xxxxx-flthdr" meaning? Could you figure out in detail?[/b] --- Quote End --- the exec format in uclinux is "binary flat" or "flt" in short. I need to know the headers of the exec, eg pppd, in both platform. For nios2, xxxx is nios2-linux-uclibc-flthdr (or nios2-elf-flthdr) For arm, it may be arm-elf-flthdr ? <div class='quotetop'>QUOTE </div> --- Quote Start --- 1. elf2flt -s 16000 / elf2flt -s 8192[/b] --- Quote End ---nios2-linux-uclibc-elf2flt
or nios2-elf-elf2flt
will show the usage. -s set stack size <div class='quotetop'>QUOTE </div> --- Quote Start --- 2. gcc -Wl (Does -W have anymore flags? ) or , pls show us how to find more information about hwo to use gcc ?[/b] --- Quote End --- Those flags are used pass options to linker. altera/kits/nios2/documents/gnu-tools gcc.gnu.org
Hello, Hippo!
I use the XXXX-flthdr in both of the platforms,the display is as follow: <div class='quotetop'>QUOTE </div> --- Quote Start --- In nios2 platform:[/b] --- Quote End --- [nios2linux@localhost pppd]$ nios2-elf-flthdr pppd pppd Magic: bFLT Rev: 4 Build Date: Mon Mar 6 17:02:53 2006 Entry: 0x44 Data Start: 0x23c30 Data End: 0x2adf8 BSS End: 0x46d4c Stack Size: 0x1000 Reloc Start: 0x2adf8 Reloc Count: 0x1130 Flags: 0x1 ( Load-to-Ram ) <div class='quotetop'>QUOTE </div> --- Quote Start --- In arm platform:[/b] --- Quote End --- [root@localhost pppd]# arm-elf-flthdr pppd pppd Magic: bFLT Rev: 4 Build Date: Tue Jul 20 16:25:09 2004 Entry: 0x50 Data Start: 0x24c60 Data End: 0x2b820 BSS End: 0x359e0 Stack Size: 0x2000 Reloc Start: 0x2b820 Reloc Count: 0xa2e Flags: 0x1 ( Load-to-Ram ) what do you find? Thanks.- Mark as New
I didi find problems in the flts. Let's look at detail of memory usage.
Try "cat /proc/(pid of pppd)/maps" for both paltform.- Mark as New
"cat maps" print nothing,the directory /proc/(pppd pid) is as following:
arm platform:
# cat maps# ls -l -r--r--r-- 1 root 0 0 Mar 13 10:13 mounts lrwxrwxrwx 1 root 0 0 Mar 13 10:13 exels: ls:./exe: No such file or directory lrwxrwxrwx 1 root 0 0 Mar 13 10:13 root -> / lrwxrwxrwx 1 root 0 0 Mar 13 10:13 cwd -> / -rw------- 1 root 0 0 Mar 13 10:13 mem -r--r--r-- 1 root 0 0 Mar 13 10:13 maps -r--r--r-- 1 root 0 0 Mar 13 10:13 statm -r--r--r-- 1 root 0 0 Mar 13 10:13 stat -r--r--r-- 1 root 0 0 Mar 13 10:13 cmdline -r--r--r-- 1 root 0 0 Mar 13 10:13 status -r-------- 1 root 0 0 Mar 13 10:13 environ dr-x------ 2 root 0 0 Mar 13 10:13 fd nios2 flatform:
# cat maps# ls -l -r-------- 1 root root 0 Nov 30 00:01 auxv -r--r--r-- 1 root root 0 Nov 30 00:00 cmdline lrwxrwxrwx 1 root root 0 Nov 30 00:01 cwd -> / -r-------- 1 root root 0 Nov 30 00:01 environ lrwxrwxrwx 1 root root 0 Nov 30 00:01 exels: ./exe: No such f le or directory dr-x------ 2 root root 0 Nov 30 00:01 fd -r--r--r-- 1 root root 0 Nov 30 00:01 maps -rw------- 1 root root 0 Nov 30 00:01 mem -r--r--r-- 1 root root 0 Nov 30 00:01 mounts -rw-r--r-- 1 root root 0 Nov 30 00:01 oom_adj -r--r--r-- 1 root root 0 Nov 30 00:01 oom_score lrwxrwxrwx 1 root root 0 Nov 30 00:01 root -> / -r--r--r-- 1 root root 0 Nov 30 00:00 stat -r--r--r-- 1 root root 0 Nov 30 00:01 statm -r--r--r-- 1 root root 0 Nov 30 00:01 status dr-xr-xr-x 3 root root 0 Nov 30 00:01 task
ll
Please remove your e-mail address in previous post.
Sorry, there is no /proc//maps in nios uclinux. Please try /proc/(your ppd process id)/status and statm.- Mark as New
hippo,Thanks you a lot.
this the result: <div class='quotetop'>QUOTE </div> --- Quote Start --- nios flatforum[/b] --- Quote End --- :# cat /proc/74/status
State: S (sleeping)
SleepAVG: 87%
Tgid: 74
Pid: 74
PPid: 64
TracerPid: 0
Uid: 0 0 0 0
Gid: 0 0 0 0
FDSize: 32
Groups:
Mem: 544160 bytes
Slack: 229815 bytes
Shared: 0 bytes
Threads: 1
SigPnd: 0000000000000000
ShdPnd: 0000000000000000
SigBlk: 0000000000000000
SigIgn: 0000000000081006
SigCgt: 0000000057816ef9
CapInh: 0000000000000000
CapPrm: 00000000fffffeff
CapEff: 00000000fffffeff# cat /proc/74/statm
1065672 1065672 0 146416 0 377528 0
<div class='quotetop'>QUOTE </div> --- Quote Start --- arm platform[/b] --- Quote End --- # cat /proc/65/status
State: S (sleeping)
Tgid: 65
Pid: 65
PPid: 44
TracerPid: 0
Uid: 0 0 0 0
Gid: 0 0 0 0
FDSize: 32
Groups:
Mem: 239584 bytes
Slack: 1292 bytes
Shared: 0 bytes
CapEff: 00000000fffffeff# cat /proc/65/statm
113 113 0 37 0 20 0
I think there may be problems in memory management of nios2 kernel.
How about other apps? Do they have the same problems?- Mark as New
Thank you hippo for all your coaching.
my god! evey apps have this problem. the mm code is a sealed book for me. In addition,I want to download my kernel image from my pc by u-boot. Do you know how can I use the u-boot's ftp service?- Mark as New
I don't use uboot. Scott is an expert on it.
I will look at the mm code when I have time.- Mark as New
Our nios2linux Cross Compiler:
1. bin files from Altera nios2 tools CD under redhat , and we copied them to proper directories. 2. build some nessary tools according "hippo_mini_nios2linux",such as elf2flt 3. modify config.arch to export CROSS_COMPILE, CC... So we guess there are some mistakes happens. Here we copy our modified config.arch############################################################################# # Settings for building user apps#
ifdef UCLINUX_BUILD_USER
SLIBC = -lc
SLIBM = -lm
SLIBNET =# -lnet#jwq:20051010 avoid route error
SLIBDES = -ldes
SLIBAES = -laes
SLIBPCAP = -lpcap
SLIBSSL = -lssl
SLIBCRYPTO = -lcrypto
ifeq ($(LIBCDIR),libc)
SLIBCRYPT = -lcrypt_old
else
SLIBCRYPT = -lcrypt# //modi by zlx# reModified :jwq: 20051010 for avoiding pppd error
# SLIBCRYPT = -lcrypt_old
endif
SLIBPTHREAD = -lpthread
LIBC = $(SLIBC)
LIBM = $(SLIBM)
LIBNET = $(SLIBNET)
LIBDES = $(SLIBDES)
LIBAES = $(SLIBAES)
LIBPCAP = $(SLIBPCAP)
LIBSSL = $(SLIBSSL)
LIBCRYPTO = $(SLIBCRYPTO)
LIBPTHREAD = $(SLIBPTHREAD)
LIBCRYPT = $(SLIBCRYPT)
LIBGCC = -lgcc
LIBIBERTY = -liberty
LIBIO = -lio
LIBIOSTREAM = -liostream
LIBSTDCPP = -lstdc++
LDPATH =
-L$(ROOTDIR)/$(LIBCDIR)/.
-L$(ROOTDIR)/$(LIBCDIR)/lib
-L$(ROOTDIR)/lib/libm
-L$(ROOTDIR)/lib/libnet
-L$(ROOTDIR)/lib/libdes
-L$(ROOTDIR)/lib/libaes
-L$(ROOTDIR)/lib/libpcap
-L$(ROOTDIR)/lib/libcrypt_old
-L$(ROOTDIR)/lib/libssl
-L$(ROOTDIR)/lib/zlib
INCLIBC = -I$(ROOTDIR)/$(LIBCDIR)/include
INCLIBM = -I$(ROOTDIR)/lib/libm
INCNET = -I$(ROOTDIR)/lib/libnet
INCDES = -I$(ROOTDIR)/freeswan/libdes
INCAES = -I$(ROOTDIR)/freeswan/libcrypto/libaes
INCGMP = -I$(ROOTDIR)/lib/libgmp
INCPCAP = -I$(ROOTDIR)/lib/libpcap
INCSSL = -I$(ROOTDIR)/lib/libssl/include
INCZ = -I$(ROOTDIR)/lib/zlib
INCVEND = -I$(ROOTDIR)/vendors/include
INCCRYPTOLD = -I$(ROOTDIR)/lib/libcrypt_old
ifdef CONFIG_USER_DEBUG
CFLAGS := $(if $(UOPT),$(UOPT),-O1) -g
else
CFLAGS := $(if $(UOPT),$(UOPT),-O2) -g -Wall -fomit-frame-pointer
endif
CFLAGS += $(CPUFLAGS)
CFLAGS += $(VENDOR_CFLAGS)
CFLAGS += -Dlinux -D__linux__ -Dunix -D__uClinux__ -DEMBED
CFLAGS += $(INCLIBC) $(INCLIBM) $(INCCRYPTOLD)
CFLAGS += -I$(ROOTDIR)
CFLAGS += -fno-builtin
CFLAGS += -nostartfiles
ifndef DISABLE_XIP
CFLAGS += -D__PIC__ -fpic -msingle-pic-base
endif
# the following is needed for 2.4
CFLAGS += -I$(ROOTDIR)/$(LINUXDIR)/include
CXXFLAGS = $(CFLAGS) $(INCCXX)
LDFLAGS = $(CFLAGS) -Wl,-elf2flt $(ROOTDIR)/lib/libc/crt0.o
else
# LDFLAGS = $(CFLAGS) -Wl,-elf2flt $(ROOTDIR)/lib/$(LIBCDIR)/lib/crt0.o
# $(ROOTDIR)/lib/$(LIBCDIR)/lib/crti.o
# $(ROOTDIR)/lib/$(LIBCDIR)/lib/crtn.o
# jwq:20051005
LDFLAGS = $(CFLAGS) -Wl,-elf2flt $(ROOTDIR)/$(LIBCDIR)/lib/crt0.o
$(ROOTDIR)/$(LIBCDIR)/lib/crti.o
$(ROOTDIR)/$(LIBCDIR)/lib/crtn.o
endif
ifndef DISABLE_MOVE_RODATA
LDFLAGS += -Wl,-move-rodata
endif
LDFLAGS += $(LDPATH)
LDLIBS = $(LIBC)
LDLIBS_static = $(SLIBC)
CXXLIBS = $(LIBSTDCPP) $(LIBIOSTREAM) $(LIBIO) $(LIBIBERTY)
$(LIBC) $(LIBGCC)# ############################################################################# from nios Rules.mak in order to add right uClibc for nios only
CRT0 := $(ROOTDIR)/$(LIBCDIR)/lib/crt0.o
LIBC := $(ROOTDIR)/$(LIBCDIR)/lib/libc.a
LIBGCC := $(shell $(CC) -print-file-name=libgcc.a)
LIBM := $(shell $(CC) -print-file-name=libm.a)
LIBGCCDIR := $(dir $(LIBGCC))
LINKSCRIPT := $(UTILSDIR)/elf2flt.ld
LDFLAGS := -msys-crt0=$(CRT0) -r -d -L$(ROOTDIR)/$(LIBCDIR)/lib
LDLIBS := $(LIBM) $(LIBGCC) $(LIBC)
# ############################################################################# from nios Rules.mak in order to add right uClibc for nios only# but now it is not used # because old arm one(CFLAHS)seems OK# CFLAGS := -nostdinc -D__linux__ -O2 -I$(ROOTDIR)/$(LINUXDIR)/include -I"d:/EDA/altera/kits/nios5/bin/eclipse/plugins/com.microtronix.nios2linux.uClibc_1.4.0"/include -I/cygdrive/d/EDA/altera/kits/nios5/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.1//include -fno-optimize-sibling-calls -mhw-mul -mhw-mulx -Wall# ##################
ifndef FLTFLAGS
FLTFLAGS :=
endif
export FLTFLAGS
# for anyone still using it
CONVERT = /bin/true
UCLINUX_BUILD_SET=1
endif# ###########################################################################
and an example of makefile under a user application #jwq:20051017
PROJ_NAME=chat
EXEC = $(PROJ_NAME).exe
OBJS = chat.o
ifdef CONFIG_USER_CHAT_CHAT_NETWORK
CFLAGS += -DENABLE_NETWORK_SUPPORT=1
endif
all: $(EXEC)# jwq:20051017
$(PROJ_NAME).bin: $(OBJS)
$(CC) $(LDFLAGS) -o $@ $(OBJS) $(LDLIBS)
romfs:
$(ROMFSINST) /bin/$(PROJ_NAME)
clean:
-rm -f $(EXEC) *.elf *.gdb *.o *.bin *.exe $(PROJ_NAME)# ############################################################################ default stack size is 4K# # jwq:20051017
FLTFLAGS:=
WARNING_FLAGS := -Wall
%.exe : %.flt
cp -f $< $@
cp -f $@ $(PROJ_NAME)# # Make a relocatable flat file from an ELF file.# STACKSIZE is defined by individual makefiles.#
%.flt : %.elf
$(ELF2FLT) $(FLTFLAGS) -o $@ $<
# # Make a relocatable ELF file.#
%.elf : %.bin
$(LD) -T $(LINKSCRIPT) -Ur -o $@ $<
there is one big difference: we find that "-elf2flt" in LDFLAGS has no effect in original Makefile, so we modified Makefile to ELF2FLT explicitly in one step according to Microtronix's did in Nios2IDE. here are messages in compling: nios2-elf-gcc -O2 -g -Wall -fomit-frame-pointer -Dlinux -D__linux__ -Dunix -D__uClinux__ -DEMBED -I/home/nios2linux/user_nios2linux/../uClibc_1.4.0/include -I/home/nios2linux/user_nios2linux/lib/libm -I/home/nios2linux/user_nios2linux/lib/libcrypt_old -I/home/nios2linux/user_nios2linux -fno-builtin -nostartfiles -I/home/nios2linux/user_nios2linux/../linux-2.6.x/include -c -o interface.o interface.c
nios2-elf-gcc -msys-crt0=/home/nios2linux/user_nios2linux/../uClibc_1.4.0/lib/crt0.o -r -d -L/home/nios2linux/user_nios2linux/../uClibc_1.4.0/lib -o loadconfig.bin loadconfig.o conf.o util.o user.o interface.o ../public_function/mysem.o ../public_function/i2c-usr.o /usr/local/bin/../lib/gcc/nios2-elf/3.4.1/../../../../nios2-elf/lib/libm.a /usr/local/bin/../lib/gcc/nios2-elf/3.4.1/libgcc.a /home/nios2linux/user_nios2linux/../uClibc_1.4.0/lib/libc.a -lcrypt
nios2-elf-ld -T /usr/local/bin/elf2flt.ld -Ur -o loadconfig.elf loadconfig.bin
/usr/local/bin/nios2-elf-elf2flt -o loadconfig.flt loadconfig.elf
cp -f loadconfig.flt loadconfig.exe
cp -f loadconfig.exe loadconfig
rm loadconfig.flt loadconfig.elf
Yes, mountain8848 may be right. It could be problem of your build system.
I tested inetd, ftpd and boa on my board, and there is no mm problem. I would suggest you try the guide on linux, http://forum.niosforum.com/forum/index.php?showtopic=3174 (http://forum.niosforum.com/forum/index.php?showtopic=3174)
Topic Options
