I want to write data to sdram via nios2, then read data out and connect to LEDs to see if the data is correct.
Below is my code and results.
In the code I add printf("isr\n") to make sure interrupt is in effect.
Before "return 0" in the main(), I add printf("b\n") to check if the program is executed outside of while(1) loop, which is not allowed.
But when I write to the 65th date, the program is stuck,
and the interrupt is not working also.
I don't know what happened,
could anyone help me?
thanks a lot!
2019/3/21 update:
I attach my fpga file,
for .elf file please use SPCM2.
#include <stdio.h>
#include <unistd.h>
#include "system.h"
#include "alt_types.h"
#include "io.h"
#include "altera_avalon_pio_regs.h"
#include "sys/alt_irq.h"
int bKeyPressed = 0;
int cnt = 1;
alt_u16 incre = 0;
alt_u16 data, data0;
void KEY_ISR(void* context){
bKeyPressed = 1;
IOWR_ALTERA_AVALON_PIO_EDGE_CAP(KEY_BASE,0);
printf("isr\n");
void EnableKeyInterrupt(void){
int error;
IOWR_ALTERA_AVALON_PIO_IRQ_MASK(KEY_BASE,0x03);
bKeyPressed = 0;
error = alt_irq_register (KEY_IRQ, 0, KEY_ISR);
if (error)
printf("Failed to register interrut\r\n");
int main()
EnableKeyInterrupt();
IOWR(LED_BASE, 0, (alt_u8)0);
while(1)
if(bKeyPressed)
bKeyPressed = 0;
*((alt_u8*)NEW_SDRAM_CONTROLLER_0_BASE + incre) = cnt;
data = *((alt_u8*)NEW_SDRAM_CONTROLLER_0_BASE + incre);
printf("cnt = %d, ", cnt);
printf("incre = %d, ", incre);
printf("data=%d\n", data);
IOWR(LED_BASE, 0, (alt_u8)data);
cnt ++;
incre += 1;
printf("b\n");
return 0;
isr
cnt = 1, incre = 0, data=1
isr
cnt = 2, incre = 1, data=2
isr
cnt = 3, incre = 2, data=3
isr
cnt = 4, incre = 3, data=4
isr
cnt = 5, incre = 4, data=5
isr
cnt = 6, incre = 5, data=6
isr
cnt = 65, incre = 64, data=65
Without your Qsys / Platform Designer code it is not easy to help you.
But based on what I see, there is no limit to the value that "incre" can have.
Therefore sooner or later you risk to write beyond the limits of the dedicated memory.
Also it is very well possible that you are writing into the zones that are used for other purposes hence making your system unstable.
Johi.
Hi Johi,
Thanks for the reply,
my qsys and top level are as below,
I use the onchip memory as nios2 cpu's memory.
Yes, it's very likely that data is written into the zone that is for other purpose,
is there any way to avoid it?
adam
module SPCM_NIOS(
//////////// CLOCK //////////
CLOCK_50,
//////////// LED //////////
LED,
//////////// KEY //////////
KEY,
//////////// SDRAM //////////
DRAM_ADDR,
DRAM_BA,
DRAM_CAS_N,
DRAM_CKE,
DRAM_CLK,
DRAM_CS_N,
DRAM_DQ,
DRAM_DQM,
DRAM_RAS_N,
DRAM_WE_N,
//////////// GPIO_0, GPIO_0 connect to GPIO Default //////////
GP0,
GP0_IN,
//////////// GPIO_1, GPIO_1 connect to GPIO Default //////////
GP1,
GP1_IN
// PARAMETER declarations
// PORT declarations
input CLOCK_50;
output [7:0] LED;
input [1:0] KEY;
output [12:0] DRAM_ADDR;
output [1:0] DRAM_BA;
output DRAM_CAS_N;
output DRAM_CKE;
output DRAM_CLK;
output DRAM_CS_N;
inout [15:0] DRAM_DQ;
output [1:0] DRAM_DQM;
output DRAM_RAS_N;
output DRAM_WE_N;
inout [33:0] GP0;
input [1:0] GP0_IN;
inout [33:0] GP1;
input [1:0] GP1_IN;
spcm_qsys u0 (
.clk_50_clk (CLOCK_50), // clk_50.clk
.rst_n_reset (KEY[0]), // rst_n.reset
.clk_sdram_clk_clk (DRAM_CLK), // clk_sdram_clk.clk
.new_sdram_controller_0_wire_addr (DRAM_ADDR), // new_sdram_controller_0_wire.addr
.new_sdram_controller_0_wire_ba (DRAM_BA), // .ba
.new_sdram_controller_0_wire_cas_n (DRAM_CAS_N), // .cas_n
.new_sdram_controller_0_wire_cke (DRAM_CKE), // .cke
.new_sdram_controller_0_wire_cs_n (DRAM_CS_N), // .cs_n
.new_sdram_controller_0_wire_dq (DRAM_DQ), // .dq
.new_sdram_controller_0_wire_dqm (DRAM_DQM), // .dqm
.new_sdram_controller_0_wire_ras_n (DRAM_RAS_N), // .ras_n
.new_sdram_controller_0_wire_we_n (DRAM_WE_N), // .we_n
.key_export (KEY),
.led_export (LED)
endmodule
Hi FJumaah,
Thanks for the reply!
Now I modify my code to use alt_ic_isr_register(...) function,
But unfortunately, the code is still stuck at the 65th press of the key😞
whether alt_ic_isr_register or alt_irq_register the results are the same.
#include <stdio.h>
#include <unistd.h>
#include "system.h"
#include "io.h"
int cnt = 1;
alt_u16 incre = 0;
alt_u16 data;
volatile int edge_capture;
bKeyPressed = 1;
// clear interrupt flag
printf("isr\n");
static void init_button_pio(){
void* edge_capture_ptr = (void*) &edge_capture;
// enable interrupt, 2-keybutton
// clear capture flag
#ifdef ALT_ENHANCED_INTERRUPT_API_PRESENT
KEY_IRQ_INTERRUPT_CONTROLLER_ID,
KEY_IRQ,
KEY_ISR,
edge_capture_ptr,
0x0);
printf("ENHANCED mode\n");
#else
alt_irq_register (KEY_IRQ, edge_capture_ptr, KEY_ISR);
printf("LEGACY mode\n");
#endif
int main()
init_button_pio();
while(1)
if(bKeyPressed)
bKeyPressed = 0;
printf("data=%x\n", data);
cnt ++;
incre += 1;
printf("b\n");
return 0;
