Hi, I'm using a CFI Flash memory.
When I interrogate the Flash, by :
[code=c]
flash_region* regions;
alt_flash_fd* fd;
int number_of_regions = 0;
int ret_code = 0;
int i = 0;
int size = 0; // taille de la flash calculée à partir des infos de régions flash
// ouverture de la flash
fd = alt_flash_open_dev(FLASH_GENERIC_TRISTATE_CONTROLL ER_NAME);
// affichage d'info sur la flash
if (fd)
ret_code = alt_get_flash_info(fd, ®ions, &number_of_regions);
if (number_of_regions )
printf("Flash information :\n");
printf("\tlength : %i\n", fd->length);
for (i=0 ; i < number_of_regions ; i++)
printf("\tregion_info[%i]\n", i);
printf("\t\toffset : %i\n", fd->region_info[i].offset);
printf("\t\tregion_size : %i\n", fd->region_info[i].region_size);
printf("\t\tnumber_of_blocks : %i\n", fd->region_info[i].number_of_blocks);
printf("\t\tblock_size : %i\n", fd->region_info[i].block_size);
[/code]
It says
Flash information :
length : [color =red] 4194304[/color]
region_info[0]
offset : 0
region_size : 4128768
number_of_blocks : 63
block_size : 65536
region_info[1]
offset : 4128768
region_size : 65536
number_of_blocks : 8
block_size : 8192
The addition regions gives size 4194304 Bytes, but the length gives 4194304 words (=16 bits)
I have 2 differents flash (32Mb and 64Mb) and they give both 4194304 words
fd->length is not calculated by CFI information but by QSYS.
Can someone confirm this ?
By a# define MACRO in altera_avalon_cfi_flash.h : #define ALTERA_AVALON_CFI_FLASH_INSTANCE(name, dev) ...
(fd -> length) takes information from the system.h <-- generated by BSP <-- generated with QSYS <-- flash information "embeddedsw.CMacro.SIZE" in "module_assignement" when editing the flash component in Qsys Editor. So, (fd -> length) does NOT take information from CFI flash. I put here because It may help someone else debugging.
