Application Not Compling
I'm in the process of trying to get the simple "hello_world.c" code to run from the board using Linux. I have the kernel and filesystem built and installed on the board. I'm now trying to compile the hello_world.c code in an application project. Upon clicking build project I receive the following error:
Kind Status Priority Description Resource In Folder Location
Error *** No rule to make target `hello.exe', needed by `all'. hello_world_app
Now, I made the proper edit to the makefile I built (i.e. TOPDIR = .. to TOPDIR = ./) since the makefile and hello_world.c are at the same level.
Below is my current Makefile code:
TOPDIR = ./
include $(TOPDIR)/Rules.mak
# # configurable options# - set DEBUG = 1 to turn on debugging support#
DEBUG = 0
PROJ_NAME = hello
INSTALL_DIR =
PROGS := $(PROJ_NAME).exe
CFLAGS +=
# # You should not need to modify anything beyond this point#
ifeq '$(DEBUG)' '1'
CFLAGS += -O0 -g
PROGS += $(PROGS:.exe=.gdb)
endif
all: $(PROGS)
.PHONY: clean
clean:
-rm -f *.[oad] *.elf *.gdb *.bin *.exe
.PHONY: install
install: all
ifeq "$(INSTALL_DIR)" ""
$(error No installation directory specified)
endif
mkdir -p $(INSTALL_DIR)/bin
install -v $(filter %.exe, $(PROGS)) $(INSTALL_DIR)/bin
I'm at a loss as to what could be causing this problem. My first thought would be the make target, but I created one for all. Any help here would greatly be appreciated.
Ah, simple fix.
Original code:
DEBUG = 0
PROJ_NAME = hello
INSTALL_DIR =
CFLAGS +=
I changed:
PROJ_NAME = hello
TO
PROJ_NAME = hello_world
Ok, I'm sure I'll have more questions regarding what I'm trying to do.
