12687 Discussions
Atomic compare_and_swap function
Hi all,
According the header file (D:\altera5\kits\nios2_50\bin\eclipse\plugins\com.microtronix.nios2linux.uClibc_1.4.0\include\bits\atomicity.h),
the implemented function is only STUB (not really atomic!).
Does anyone know how to do it really atomic?
I thought that the simplest way is to disable the interrupt when doing this function and re-enable the interrupt afterwards.
So I need to know how to enable/disable interrupt ??
Kwok Wong
--- Quote Start ---
originally posted by kwokwong@Nov 2 2006, 10:14 PM
hi all,
according the header file (d:\altera5\kits\nios2_50\bin\eclipse\plugins\com.microtronix.nios2linux.uclibc_1.4.0\include\bits\atomicity.h),
the implemented function is only stub (not really atomic!).
does anyone know how to do it really atomic?
i thought that the simplest way is to disable the interrupt when doing this function and re-enable the interrupt afterwards.
so i need to know how to enable/disable interrupt ??
regards,
kwok wong
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=19104)
--- quote end ---
--- Quote End ---
It is not implemented, so we need a nios2 version in,
uClibc/libc/sysdeps/linux/nios2/bits/atomicity.h
Look at other arch, eg, arm,m68k,mips,i386, they use locked exchange instead of disable interrupt.
Are there locked instructions in Nios2?
--- Quote Start ---
originally posted by hippo+nov 2 2006, 11:52 pm--><div class='quotetop'>quote (hippo @ nov 2 2006, 11:52 pm)</div>
--- quote start ---
<!--quotebegin-kwokwong@Nov 2 2006, 10:14 PM
hi all,
regards,
kwok wong
--- quote end ---
--- Quote End ---
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=19108)</div>
[/b]
--- Quote End ---
$ find uClibc -name "atomic*.h"
uClibc/libc/sysdeps/linux/sh/bits/atomic.h
uClibc/libc/sysdeps/linux/arm/bits/atomicity.h
uClibc/libc/sysdeps/linux/i386/bits/atomic.h
uClibc/libc/sysdeps/linux/i386/bits/atomicity.h
uClibc/libc/sysdeps/linux/m68k/bits/atomicity.h
uClibc/libc/sysdeps/linux/mips/bits/atomic.h
uClibc/libc/sysdeps/linux/mips/bits/atomicity.h
uClibc/libc/sysdeps/linux/alpha/bits/atomic.h
uClibc/libc/sysdeps/linux/alpha/bits/atomicity.h
uClibc/libc/sysdeps/linux/h8300/bits/atomicity.h
uClibc/libc/sysdeps/linux/sparc/bits/atomicity.h
uClibc/libc/sysdeps/linux/common/bits/atomic.h
uClibc/libc/sysdeps/linux/common/bits/atomicity.h
uClibc/libc/sysdeps/linux/x86_64/bits/atomic.h
uClibc/libc/sysdeps/linux/x86_64/bits/atomicity.h
uClibc/libc/sysdeps/linux/powerpc/bits/atomic.h
uClibc/libc/sysdeps/linux/powerpc/bits/atomicity.h
uClibc/include/bits/atomic.h
uClibc/include/bits/atomicity.h
uClibc/include/atomic.h
If we create uClibc/libc/sysdeps/linux/nios2/bits/atomicity.h ,then it will become uClibc/include/bits/atomicity.h . Otherwise, it will come from uClibc/libc/sysdeps/linux/common/bits/atomicity.h, which is a stub.
If nios2 does not have lock, then we can use disable/enable interrupr, with inline assembly.
TO_BE_DONE
Look in include/asm (ie, asm-nios2nommu) /system.h
Use,
local_irq_save(x) // to disable global irq
then,
local_irq_restore(x) // to enable/restore global irq
--- Quote Start ---
originally posted by hippo@Nov 7 2006, 12:47 AM
look in include/asm (ie, asm-nios2nommu) /system.h
use,
then,
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=19239)
--- quote end ---
--- Quote End ---
Thank you, hippo!
F.Y.I.
Use the macro COMPARE_AND_SWAP in stead of the function compare_and_swap.
E.g.
static inline int __compare_and_swap(volatile int *p, int old_val, int new_val)
int result;
unsigned long int_context;
/* save int. and disable all interrupts */
local_irq_save(int_context);
result = compare_and_swap((volatile long*)p, old_val, new_val);
/* re-enable interrupt */
local_irq_restore(int_context);
return result;
# define COMPARE_AND_SWAP(addr, old_val, new_val)
__compare_and_swap(addr, old_val, new_val) http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
