12699 Discussions
BINFMT_FLAT: bad header magic
Hello everyone
When I want to run a application software on NIOS II & uCLiunx, I got these fault message, how could I solve it?
<div class='quotetop'>QUOTE </div>
--- Quote Start ---
app_name:applet not found[/b]
--- Quote End ---
THX!
--- Quote Start ---
originally posted by goral@May 2 2006, 03:26 PM
hello everyone
when i want to run a application software on nios ii & ucliunx, i got these fault message, how could i solve it?
<div class='quotetop'>quote
--- quote end ---
--- quote start ---
binfmt_flat: bad header magic
--- Quote End ---
THX!
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=14927)</div>
[/b]
--- Quote End ---
You application should be converted to FLAT format with -elf2flt link flag.
Please check step11 and step15 in the buildroot guide.
--- Quote Start ---
Please check step11 and step15 in the buildroot guide.[/b]
--- Quote End ---
Thanks for youy reply!
But the application software not include in busybox, such as servfox or other application, how do I change the Makefile.
Thans!
--- Quote Start ---
--- quote end ---
--- quote start ---
you application should be converted to flat format with -elf2flt link flag.
please check step11 and step15 in the buildroot guide.
--- Quote End ---
Thans!
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=14942)</div>
[/b]
--- Quote End ---
You have to find out link command, and add the elf2flt flags.
You can take the patches for others applications as examples, in step13 of the guide.
--- Quote Start ---
Mem-info:
DMA per-cpu:
cpu 0 hot: high 0, batch 1 used:0
cpu 0 cold: high 0, batch 1 used:0
DMA32 per-cpu: empty
Normal per-cpu: empty
HighMem per-cpu: empty
Free pages:      596kB (0kB HighMem)
Active:95 inactive:254 dirty:0 writeback:0 unstable:0 free:149 slab:996 mapped:0
pagetables:0
DMA free:596kB min:360kB low:448kB high:540kB active:380kB inactive:1016kB prese
nt:8192kB pages_scanned:1600 all_unreclaimable? yes
lowmem_reserve[]: 0 0 0 0
DMA32 free:0kB min:0kB low:0kB high:0kB active:0kB inactive:0kB present:0kB page
s_scanned:0 all_unreclaimable? no
Normal free:0kB min:0kB low:0kB high:0kB active:0kB inactive:0kB present:0kB pag
es_scanned:0 all_unreclaimable? no
HighMem free:0kB min:128kB low:128kB high:128kB active:0kB inactive:0kB present:
0kB pages_scanned:0 all_unreclaimable? no
DMA: 3*4kB 5*8kB 8*16kB 1*32kB 0*64kB 1*128kB 1*256kB 0*512kB 0*1024kB 0*2048kB
0*4096kB = 596kB
DMA32: empty
Normal: empty
HighMem: empty
2048 pages of RAM
149 free pages
518 reserved pages
0 pages shared
0 pages swap cached
scheduling while atomic: servfox/0x0000000a/38
Stack from 00285d14:<0>
    <0> 0000000a<0> 001a1438<0> 00000000<0> 00000000<0> 0003a7e8<0> 00000000<
0> 00000010<0> 001c8bf4<0>
    <0> 00000010<0> 00000042<0> 00000000<0> 001c6c90<0> 00285d88<0> 0044f8c0<
0> 001c8bf4<0> ffffc79b<0>
    <0> 00000001<0> 001a29f8<0> 00000000<0> 00200200<0> ffffc79b<0> 000195d4<
0> 0044f340<0> 0023d644<0>
    <0> 0044f600<0> ffffe000<0> 000200d0<0> 001a2aac<0> 00033614<0> 0000000a<
0> 0000009b<0> 24f47300<0>
    <0> 001c9564<0> 00000006<0> 00000000<0> 000000d0<0> 0044f340<0> 00000000<
0> 00034bc4<0> 00000000<0>
    <0> 00000001<0> 000000d0<0> 000000d0<0> 00000000<0> 00248c00<0> 00000006<
Call Trace:<0>
    <0> [<0003f644>]<0> [<00000010>]<0> [<00000002>]<0> [<00000000>]<0>
    <0> [<00028c39>]<0> [<00000000>]<0> [<00000077>]<0> [<00000001>]<0>
    <0> [<0003fa5c>]<0> [<00000004>]<0> [<0003d4e0>]<0> [<00000000>]<0>
    <0> [<00000004>]<0> [<00000007>]<0> [<00003f01>]<0> [<0000000c>]<0>
    <0> [<00000004>]<0> [<00000001>]<0> [<00000000>]<0> [<00019230>]<0>
    <0> [<00008629>]<0> [<00077b54>]<0> [<00000002>]<0> [<00000000>]<0>
    <0> [<00032360>]<0> [<00000000>]<0> [<00000000>]<0> [<00000000>]<0>
    <0> [<00000000>]<0> [<00000000>]<0> [<00000000>]<0> [<00000000>]<0>
    <0> [<00003f01>]<0> [<00000000>]<0> [<00000005>]<0> [<00000044>]<0>
    <0> [<000200d2>]<0> [<00000044>]<0> [<00000000>]<0> [<00000001>]<0>
    <0> [<00000000>]<0> [<00000014>]<0> [<00000001>]<0> [<000073dc>]<0>
    <0> [<00004728>]<0> [<000009ec>]<0> [<0000000a>]<0> [<00010000>]<0>
    <0> [<00000030>]<0> [<00020000>]<0> [<00020000>]<0> [<00003e00>]<0>
    <0> [<00000080>]<0> [<00028c39>]<0> [<0001fff2>]<0> [<000027b0>]<0>
    <0> [<0000000a>]<0> [<00000000>]<0> [<000773f0>]<0> [<00053720>]<0>
    <0> [<00000000>]<0> [<00000000>]<0> [<00000000>]<0> [<00053a2c>]<0>
    <0> [<00000000>]<0> [<00002400>]<0> [<00000f00>]<0> [<00000000>]<0>
    <0> [<00000000>]<0> [<00000000>]<0> [<00000938>]<0> [<00000006>]<0>
    <0> [<00000000>]<0> [<00000000>]<0> [<00000018>]<0> [<00000000>]<0>
    <0> [<0000000b>]<0> [<00000000>]<0> [<00000000>]<0> [<00000001>]<0>
    <0> [<00000000>]<0>
oom-killer: gfp_mask=0xd0, order=6
Stack from 00285d80:<0>
    <0> 00000006<0> 00033604[/b]
--- Quote End ---
Hi
After I compile my application software, I copy it into the /tmp folder, when I run it, I got so many message, could tell me why?
The memory problem or others?
It looks like run out of memory. The DE2 has only 8M sdram.
Try remove used file in ~/rootfs, remove unused devices in ~/download/rootfs_list, disable unused options in kernel, disable used options in busybox, use jffs2 on cfi mtd to store files or rootfs... all that help to reduce memory usage.
--- Quote Start ---
Try remove used file in ~/rootfs, remove unused devices in ~/download/rootfs_list, disable unused options in kernel, disable used options in busybox, use jffs2 on cfi mtd to store files or rootfs... all that help to reduce memory usage.[/b]
--- Quote End ---
Hi hippo
Can I using my application on my usb flash disk? I know a little about such as rootfs and jffs2.
Thanks for your reply! http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif
--- Quote Start ---
--- quote end ---
--- quote start ---
it looks like run out of memory. the de2 has only 8m sdram.
try remove used file in ~/rootfs, remove unused devices in ~/download/rootfs_list, disable unused options in kernel, disable used options in busybox, use jffs2 on cfi mtd to store files or rootfs... all that help to reduce memory usage.
--- Quote End ---
Hi hippo
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=14976)</div>
[/b]
--- Quote End ---
Yes, you can use usb disk.
If you want jffs2, read step7,8 in the buildroot guide. You have to edit drivers/mtd/maps/alters.c .
--- Quote Start ---
If you want jffs2, read step7,8 in the buildroot guide.[/b]
--- Quote End ---
Hi hippo
But when I run it on my usb disk, I got the same message, how I config it?
Thanks!
--- Quote Start ---
--- quote end ---
--- quote start ---
yes, you can use usb disk.
if you want jffs2, read step7,8 in the buildroot guide.
--- Quote End ---
Hi hippo
Thanks!
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=14980)</div>
[/b]
--- Quote End ---
Check jay&#39;s thread,
http://forum.niosforum.com/forum/index.php?showtopic=3763 (http://forum.niosforum.com/forum/index.php?showtopic=3763
First check your apps size,
niso2-linux-uclibc-flthdr apps
check your memory usage with "free" or "cat /proc/meminfo"
Did the apps fail in program loading or runtime?
