Folks,
Whilst using the NIOS I/SDK I fell upon the "make aux" flow that created map files of my build. I'm all growed up now and using the NIOS II/IDE and cant seem to find a map file. Anybody kno how to make these (.nm , .objdump) ? Thanks.Link Copied
try
NIOSII IDE Menu WINDOW->PREFERENCES->NIOSII Run and Build Settings check Generate objdump file- Mark as New
Good tip. Thanks a hundered!!!
