Can't install vmware tool
Dear all,
first,i will thank to your help,my computer is xp os ,vmware 5.5,fadora 4,when i install vmware tool use the command vmware-install.pl then emerge the following information,and can't complete vmware tool
what is the location of the directory fo C header files that match you running kernal ?[/usr/src/linux/include]
help me ,thanks
<div class='quotetop'>QUOTE </div>
--- Quote Start ---
Dear all,
first,i will thank to your help,my computer is xp os ,vmware 5.5,fadora 4,when i install vmware tool use the command vmware-install.pl then emerge the following information,and can&#39;t complete vmware tool
what is the location of the directory fo C header files that match you running kernal ?[/usr/src/linux/include][/b]
--- Quote End ---
Hi:
Maybe you need to install the gcc compiler first!
