It drive me crazy.
when I do according to http://forum.niosforum.com/forum/index.php?showtopic=3174 (http://forum.niosforum.com/forum/index.php?showtopic=3174) and mount the jffs2 fs from the epcs( the board is DE2 ,and EPCS is EPCS16) try many times and not success. the promot on the uClinux is:# mount –t jffs2 /dev/mtdblock0 /mnt Eep. No valid nodes for ino# 1 or# mknod /dev/mtdblock0 b 31 0 mknod : /dev/mtdblock0 :file exists# mount –t jffs2 /dev/mtdblock0 /mnt mount : Mounting /dev/mtdblock0 on /mnt : Device or resource busy someone help me!Link Copied
try erase the jffs2 partition with nios2-flash-programmer .
--- Quote Start --- originally posted by hippo@Jul 10 2006, 01:17 PM try erase the jffs2 partition with nios2-flash-programmer .
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16734)
--- quote end ---
--- Quote End --- I erase the jffs2 partition as following: nios2-flash-programmer --epcs --erase-all --base=0x00900800 and mount the jffs2, the problem still exist:# mount –t jffs2 /dev/mtdblock0 /mnt Eep. No valid nodes for ino# 1 or# mknod /dev/mtdblock0 b 31 0 mknod : /dev/mtdblock0 :file exists# mount –t jffs2 /dev/mtdblock0 /mnt mount : Mounting /dev/mtdblock0 on /mnt : Device or resource busy ??? What the problem indeed? http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif
