Hello.
I have a Nios V system in platform designer. I've created a bsp, then created an application project as in 1.4.3.2 in Nios® V Embedded Processor Design Handbook. Then I tried to use RiscFree IDE to compile the project and got this error:
Error: -march=rv32ima_zicbom: unknown z ISA extension `zicbom'
make[2]: *** [bsp/CMakeFiles/hal2_bsp.dir/build.make:75: bsp/CMakeFiles/hal2_bsp.dir/HAL/src/alt_log_macro.S.obj] Error 1
make[1]: *** [CMakeFiles/Makefile2:182: bsp/CMakeFiles/hal2_bsp.dir/all] Error 2
make: *** [Makefile:91: all] Error 2
My PATH var looks like this
echo $PATH
/mnt/HDD/Intel/intelFPGA_pro/23.1/riscfree/build_tools/cmake/bin:/mnt/HDD/Intel/intelFPGA_pro/23.1/riscfree/toolchain/riscv32-unknown-elf/bin/:/sbin:/bin:/usr/bin:/usr/local/bin:/snap/bin:/usr/share/bittware-sdk/bin
How can I fix this error?
i am working on your issue. please give me time.
Thank you,
https://www.rocketboards.org/foswiki/Documentation/NiosVZephyrDesignExampleHelloWorld
please follow the shared article. in this article, we can find an example design also. please follow those steps.
Hello.
Thank you for your answer.
I've found out that this error was probably due to I used Nios V/g IP core. Unfortunately I coundn't find any info about development flow for this processor and existing one for Nios V/m doesn't work for it. So after switching to Nios V/m and doing the flow from the scratch I was able to get an .elf file for my design. But also I got an error:
make[2]: niosv-stack-report: Command not found
make[2]: *** [CMakeFiles/niosv-stack-report.dir/build.make:73: main.elf.stack_report] Error 127
make[1]: *** [CMakeFiles/Makefile2:156: CMakeFiles/niosv-stack-report.dir/all] Error 2
It seems that Ashling IDE somehow doesn't find niosv-stack-report binary, while i can see it at niosv/bin directory:
$ ls intelFPGA_pro/23.1/niosv/bin/
commons-cli-1.4.jar elf2flash elf2flash.jar elf2hex elf2hex.jar niosv-app niosv-bsp niosv-download niosv-download-files niosv-shell niosv-shell-files niosv-stack-report niosv-stack-report-files
Is there any workaround for this issue?
https://www.intel.com/content/www/us/en/support/programmable/articles/000091393.html
On this page, we can find the error details. actually, you can ignore this error. complete details of this error we can see the shared page.
Thank you,
Thank you for your answer. Running Ashling IDE from niosv-shell helped.
so, based on your last message shall I take it as your issue has been solved? please confirm if it's ok I will close this case.
Thank you,
Hareesh B.
Hello Hareesh.
Yes, you can close the case. Thank you.
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 4/5 survey.
