12748 Discussions
Code size for Small Hello World
I am trying out the NIOS II running on MAX 10 FPGA. I found that by compiling the small hello world template project which just output the string "Hello from NIOS II" using the alt_putstr function, the code size is 3888 byte!
I remember the small hello world used to be very small in size. Not sure why is it becoming so large now.
I appreciate if anybody can help to shed some light and advise for me.
Maybe you can try "enable_small_c_library" and "enable_reduced_device_drivers" in BSP Editor Settings.Common.hal.
