Compact Flash
I'm using a 1GByte Compact Flash disk with the Altera 1c20 eval board. I can not write more than 500MBytes to it. Does anybody know how to solve this problem?
There should be no 512M limits.
There is a limit of 2GB on FAT filesystem.
Please try read/write to the CF drive, and bypass the FAT.
dd if=/dev/hda of=/dev/null
dd if=/dev/zero of=/dev/hda
--- Quote Start ---
originally posted by hippo@Oct 4 2006, 09:30 PM
there should be no 512m limits.
there is a limit of 2gb on fat filesystem.
please try read/write to the cf drive, and bypass the fat.
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=18553)
--- quote end ---
--- Quote End ---
I typed the dd if=/dev/hda of=/dev/null
the output was:
hda:hda1
2001888+0 records in
2001888+0 records out
after I typed: dd if=/dev/zero of=/dev/hda
hda: hda1
/dev/hda: No space left on device
2001889+0 records in
I tried using the CompactFlash in FAT and ext2, I got the same results, can not write more than 500MB to the disk.
Is it normal for the LEDs and the 7-segment displays to be counting? I did not write a routine to do that, and as soon as the system is up, it start counting.
Thanks for the input
it is possible to switch off the Leds and 7 Seg display when configuring the kernel.
Processor type and features
[] Enable leds, seven segment display
--- Quote Start ---
originally posted by nacide@Oct 6 2006, 05:39 AM
it is possible to switch off the leds and 7 seg display when configuring the kernel.
processor type and features
[] enable leds, seven segment display
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=18576)
--- quote end ---
--- Quote End ---
After performing those commands, I had to reformat the disk. Now, I&#39;m able to write more than 512MB. It seems that I missed up the Disk, when I turned the card off before umounting the disk. Why is that? In my application, the power can go away while the board is running. Is there a way out of this??
There must be a task running in the background to blink the leds, and the seven segment displays. Is this standard with the uClinux-Nios port?
You might try using a different filesystem. Since you&#39;re stating that power can go away, at any time, why not JFFS2 (or some other _journalling_ filesystem)?
In any case, I don&#39;t see your issue as specific to Nios/uCLinux (at this point), so you might try asking the question in other forums, or doing some internet sleuthing on your own.
[EDIT: Out of curiousity, I found this link (http://www.openpsion.org/howtos/series5mx_new/x176.htm). ]
Good luck!
- slacker
