Configure Kernell *Error*
This is the error:
Microtronix Linux Extensions
Version 1.2, Built Wed Jul 27 3:46pm EST 2004
make: Entering directory `/cygdrive/c/altera/kits/nios2/bin/eclipse/plugins/com.
microtronix.nios2linux.kernel_0.1.5/linux-2.6.x'
HOSTCC scripts/basic/fixdep
/usr/local/bin/ld: cannot open crt0.o: No such file or directory
But i can not find de directory on my computer.
Can someone help me ?
Hi... try unmounting your /usr/lib directory...
umount /usr/lib
you might have to try
umount -s /usr/lib
in order for it to unmount.
It's not working..
Is the command for umount not working? Or are you still getting the same error when trying to compile your kernel?
Could you pass me the results of running the mount command from within the Nios II SDK shell?
Should look something like:
C:\altera\quartus42\bin\cygwin\bin on /usr/bin type system (textmode) C:\altera\quartus42\bin\cygwin on / type system (textmode) c: on /cygdrive/c type user (textmode,noumount) d: on /cygdrive/d type user (textmode,noumount) z: on /cygdrive/z type user (textmode,noumount)
