Converting binary file to elf
Lets say I wanna covert my grep binary that I have on my linux system to elf format so I can execute it on uclinux, whats the process in doing that?
I tried:
nios2-elf-objcopy -I binary -O elf32-littlenios2 /path/to/grep /path/to/output
but the resulting elf does not work on uclinux.
By your linux system, I assume you mean your computer's system.
Can't do that mate: the binaries on your computer's system only run on x86 processors, they won't run on NIOS or any other kind of processor.
You need to cross-compile your software targeting uCLinux on NIOS.
I am looking in the /uClinux-dist/user dir and I cannot locate gawk, awk, or nawk. Is there a tutorial that shows how to cross compile from source?
Bump. Anyone?
