12671 Discussions
Cyclone V SoC - Time execution function - Cycle count
Hi everybody,
I'm new on SoC architecture and I need to measure cycle count about some function using NEON instruction.
My goal is to measure optmization code compared to an other architecture.
In Texas Instrument or Analog Devices case, I can put MACRO on code. Theses MACRO allows an hardware cycle counter in order to calculate function cycle time.
Example from Analog Devices:
  • #include <cycle_count.h>
  • START_CYCLE_COUNT(S)
  • STOP_CYCLE_COUNT(T,S)
Example from TI:
  • #include <c6x.h>
  • start_time = _itoll(TSCH, TSCL);
  • end_time = _itoll(TSCH, TSCL);)
  • cyclecount= end_time - start_time;
  • or directly with Code Composer Studio.
ARM Compiler, DS-5 on eclipse or an other tools allow that?
Thank a lot,
Remy
Hi ,
for software you can also write to rocketboard mailing list.
http://lists.rocketboards.org/mailman/listinfo
http://rocketboards.org/
Kr,
Florian
Ok Thx.
I receive an answer from altera: we can use Trace tools with DS-5 Debugger.
They is a tutorial on youtube video: https://www.youtube.com/watch?v=u_xkybphchi
Remy
I use simplest method: run my code 1000*1000(*1000...) times and see moments between writing "beg"/"end" to program console.
Precision is sufficient to make conclusion: NEON is very weak relative TI DSPs.
--- Quote Start ---
Ok Thx.
Remy
--- Quote End ---
Where were you able to find the time it would take to complete each cycle?
