12612 Discussions
DM9000 driver for NIOS2 MMU?
Is the diver dm9000.c in uClinux sources for NIOS2 MMU or only for noMMU?
It works on NIOS2 MMU and noMMU. I successfully run it.
--- Quote Start ---
--- Quote End ---
Do you use the tool sopc2dts?
I am having problems with the chip DM9000A.
The next is correct?
dm9000: ethernet@0x801470 {
compatible = "davicom,dm9000-1.0";
reg = < 0x00801470 0x00000004 >;
interrupt-parent = < &nios_ii_processor >;
interrupts = < 1 >;
address-bits = < 48 >;
max-frame-size = < 1518 >;
local-mac-address = [ 00 00 00 00 00 00 ];
}; //end ethernet@0x801470 (dm9000)
