12748 Discussions
Debug user space application with MMU
I am trying to use the gdbserver as described here:
http://nioswiki.com/linux/debug_user_space
At some point, this was working, but sometimes it wouldn't work and now I haven't had it working for a while. The application and gdb dies on a crash and doesn't let me debug. This isn't just this particular crash, I've had this happen with almost every crash while developing.
On the server:
--- Quote Start ---
root:/> gdbserver localhost:9999 myprogram
Process myprogram created; pid = 50
Listening on port 9999
Remote debugging from host 192.168.100.28
<program output...>
Child terminated with signal = b
Child terminated with signal = 0xb (SIGSEGV)
GDBserver exiting
root:/>
--- Quote End ---
On the client:
--- Quote Start ---
Program terminated with signal SIGSEGV, Segmentation fault.
The program no longer exists.
(gdb) backtrace
No stack.
--- Quote End ---
Any advice?
Also, the wiki says "we will add the gdbserver source to uclinux-dist later" -- is there any progress on this? Could the gdbserver currently in uclinux-dist work?
Debugging after a crash might be difficult. Are you sure it's just with NIOS ?
I just read a good book about working with gdb:
the art of debugging with gdb, ddd and eclipse: for professionals and students (http://www.amazon.de/art-debugging-gdb-eclipse-professionals/dp/1593271743/ref=sr_1_3?ie=utf8&s=books-intl-de&qid=1266605020&sr=8-3) by Norman Matloff und P. J. Salzma
-Michael
In the cases when I could run the program on my PC, I could debug the crash using gdb, so it is something with the NIOS gdbserver provided with the mmu toolchain.
Just wanted to add that breakpoints don't work either, with the same result, the program just terminates:
Program terminated with signal SIGTRAP, Trace/breakpoint trap.
Not having the debugger available is really eating up a lot of time :-(
--- Quote Start ---
--- Quote End ---
When the debuggee program crashes, the 'gdbserver' will terminate itself. So please get debuggee's 'coredump' file by setting 'ulimit -c ***', for example in your 'bash', And copy it to your PC, and read it by Nios's 'gdb' with the command 'core-file core'. I think that you can reach the position which causes the crash. Then set a breakpoint there and...
And don't forget to compile your program with the option switch '-O0'.
--- Quote Start ---
--- Quote End ---
SIGTRAP? Really?
Kazu
I realized when somebody mentioned it in the other thread on this topic (http://www.alteraforum.com/forum/showthread.php?t=19322) that I am not actually quite following the directions there.
I am not using
set solib-absolute-prefix ~/nios2-linux/toolchain-mmu/x86-linux2/nios2-wrs-linux-gnu/libc
but instead the libs in the romfs:
set solib-absolute-prefix /data/nios/nios2-linux/uClinux-dist/romfs/
Since all the libraries I am using need to be on the device for the application to run, I think this should not make a difference.
--- Quote Start ---
--- Quote End ---
I am trying to use a core file now. I am running `nios2-linux-gnu-gdb mynios2program`, with set solib-absolute-prefix /data/nios/nios2-linux/uClinux-dist/romfs/ in .gdbinit. Then core-file mycorefile, but all I can get is:
warning: Couldn't find general-purpose registers in core file. # 0 0x00000000 in ?? ()
--- Quote Start ---
warning: Couldn't find general-purpose registers in core file.# 0 0x00000000 in ?? ()
--- Quote End ---
Do you have enough space for the core dump file? For example,
ulimit -c unlimiled
Kazu
I am debugging a user application and I have some doubts, and maby someone can answer my questions.
My application produces a segmentation fault, I suppose that a segmentation fault provoke a core dumped, is this true?
If I want to have core dumps in uClinux, as kazuyasu commented in last posts I have to insert the command : ulimit -c unlimited. But where is it in the configuration kernel?, I haven't found.
And my last question is, is the core file created in /proc/sys/kernel?, if not where is it found?
Many thanks
--- Quote Start ---
--- Quote End ---
Yes, but the dumping is limited by 'core file size', and it's 0 by default.
--- Quote Start ---
--- Quote End ---
'ulimit -c ***' that I mentioned before is an internal command of 'bash' and you don't need to configure your kernel in general. See also
http://linux.die.net/man/3/ulimit
--- Quote Start ---
--- Quote End ---
In general, the core dump file is made in your 'current working directory'.
http://linux.die.net/man/5/core
Kazu
Hi Kazu,
I have changed the shell to ash and now I can see the core file.
Many thanks
This may be related to troubles debugging. I am trying to print a stack trace from within the program, but that doesn't work either. I tried with a very simple non-threaded C program:
#include <stdio.h> # include <execinfo.h> # include <stdlib.h> void print_trace() { void *array; size_t size; // get void*'s for all entries on the stack size = backtrace(array, 10); // print out all the frames to stderr fprintf(stderr, "trace size %zu:\n", size); backtrace_symbols_fd(array, size, 2); exit(1); } void baz() { print_trace(); } void bar() { baz(); } void foo() { bar(); } int main(int argc, char **argv) { foo(); }
When I build this on my PC (Ubuntu 10.10 x86_64) I get a nice stacktrace:
gcc -g -rdynamic -o test_bt test_bt.c
trace size 7: ./test_bt(print_trace+0x19) ./test_bt(baz+0xe) ./test_bt(bar+0xe) ./test_bt(foo+0xe) ./test_bt(main+0x19) /lib/libc.so.6(__libc_start_main+0xfe) ./test_bt
On Nios II Linux I just get this:
nios2-linux-gnu-gcc -g -rdynamic -o test_bt test_bt.c
trace size 1:
I've been trying to mess with compiler flags, but haven't found any magic so far. Any ideas?
--- Quote Start ---
--- Quote End ---
I hit the same problem here too and traced it down to the kernel writing a faulty corefile, missing the .reg and .reg/<N> section. The cause for this was ELF_NGREG in arch/nios2/include/asm/elf.h being too small ((sizeof (struct pt_regs) / sizeof(elf_greg_t)), while ELF_CORE_COPY_REGS also writes all registers from struct switch_stack to the buffer.
If ELF_NGREG is defined as in the following patch, the corefile is generated properly and can be used with nios2-linux-gnu-gdb:
-#define ELF_NGREG (sizeof (struct pt_regs) / sizeof(elf_greg_t)) +#define ELF_NGREG ((sizeof(struct pt_regs) + sizeof(struct switch_stack)) / sizeof(elf_greg_t))
I'll also apply this fix to the nios2 branch of the nios2-linux kernel git repository.
Tobias, I just saw this fix in the commit log and was surprised to see a link back to my report here because I missed your response in the thread. I will try this fix!
--- Quote Start ---
--- Quote End ---
Have you get it to work, ykozlov? I couldn't print out a stacktrace in a user-level program with backtrace() / backtrace_symbols()...
--- Quote Start ---
--- Quote End ---
No, I never got that working, but tklauser's kernel fix did fix debugging using a core dump.
--- Quote Start ---
--- Quote End ---
And I fixed the backtrace() function... or bypass it and wrote my own!
stackframe.c # define _GNU_SOURCE # include <stdio.h># include <inttypes.h># include <stdint.h># include <ucontext.h># include <dlfcn.h># include <string.h> struct frame { void *fp; // frame pointer void *ra; // return address }; void print_symbol(void *address) { Dl_info info; char library; char function; void *symbol_address; if (dladdr(address, &info) == 0) { strncpy(function, "???", sizeof(function)); strncpy(library, "???", sizeof(library)); symbol_address = 0; } else { strncpy(function, info.dli_sname, sizeof(function)); strncpy(library, info.dli_fname, sizeof(library)); symbol_address = info.dli_saddr; } printf("0x%08X %s: %s\n", (uint32_t) symbol_address, library, function); } void backtrace() { struct frame *frame; // frame = CURRENT_FRAME_POINTER __asm("mov %0,r28" : "=r"(frame)); // Last frames while (frame && frame->fp) { printf("fp = 0x%08X ra = 0x%08X\n", (uint32_t) frame->fp, (uint32_t) frame->ra); print_symbol((void *) frame->ra); frame = (struct frame *) frame->fp; } } void test3() { backtrace(); } void test2() { test3(); } void test1() { test2(); } int main(int argc, char *argv) { test1(); return 0; }Makefile CC = nios2-linux-gnu-gcc CFLAGS = -Wall -fno-omit-frame-pointer LDFLAGS = -rdynamic -ldl SOURCES = stackframe.c OBJECTS = $(SOURCES:%.c=%.o) PROGRAM = stackframe .PHONY: all clean all: $(PROGRAM) clean: rm -rf $(OBJECTS) $(PROGRAM) build: clean all $(PROGRAM): $(OBJECTS) $(CC) -o $@ $(OBJECTS) $(LDFLAGS) %.o: %.c $(CC) $(CFLAGS) -c $< Build: $ make nios2-linux-gnu-gcc -Wall -fno-omit-frame-pointer -c stackframe.c nios2-linux-gnu-gcc -o stackframe stackframe.o -rdynamic -ldl Execute: # stackframe fp = 0x7FE81D24 ra = 0x00001838 0x00001824 stackframe: test3 fp = 0x7FE81D2C ra = 0x00001860 0x0000184C stackframe: test2 fp = 0x7FE81D34 ra = 0x00001888 0x00001874 stackframe: test1 fp = 0x7FE81D44 ra = 0x000018B8 0x0000189C stackframe: main
