Folks,
I recently began porting my NIOS II design to its final hardware platform from the 1C20 eval board. During this effort, I eliminated reset by assigning it internally to '0'. My logic uses active high-reset so all the reset logic and routing disappeared. The NIOS II uses active low reset so its reset is inverted before entering the NIOS II component. When reset is set '0' (inactive), the NIOS II core did not boot. I tested this by supplying reset only to the NIOS II component. When I did this, the NIOS II booted normally (all this testing done on the 1C20 eval bd). Does the NIOS II core need a reset? I thought I got one for "free" when the device configured.Link Copied
Not sure what you mean by that since you figured out the NIOS core will not function without it.
Pretty much any processor needs a reset so that it starts at the correct reset location (if you power up a processor in an undefined state, you don't have a clue how it could react in some situations). Also keep in mind the symbol you are looking at on the screen in your block diagram is not just the NIOS processor in, but the whole SOPC system. Removing reset logic from the rest of those devices is not a good idea for two reasons: 1) you will not know their behaviour since they are not your core 2) designers don't put in resets for no reason at all.- Mark as New
But, I thought after configuration, all internals of the FPGA should be in the reset state?
I did several design s in the past with SpartanXL components from the manufacturer known as X. There it was no problem at all. I believe if it is a processor, or a state machine (whats the difference?) or something else, it shouldn't matter. Stefaan- Mark as New
Oh after downloading his hardware design (thought he was talking about downloading just his code using the IDE). Yes when you download your system design the reset will get triggered, however it's a good design practice to put resets in yourself. Sometimes but not often you can have a PLD not come out of reset properly.
As to your other question, a state machine is different from a processor (althought it's not impossible to make a processor from a state machine, but you'll need to lock yourself in a room for years to achieve this) in that it usually has a finite number of states. They are useful for systems that are not too complicated, but a processor has data stored as variables, so the number of states your processor can have is every combination of values over all memory locations (so lets just call that an infinite state machine). If you want to see the logic behind a state machine go to the templates in Quartus and call up the state machine with the asyn. reset and that may explain the structure to them (a condition to make you change/stay in a state, and an output dependent on the state you are in).- Mark as New
The Nios II was designed to operate in an FPGA or in a hardcopy/ASIC implementation.
In the latter, the RAMs internal to the Nios II (e.g. register file and caches) are not initialized on poweron. The Nios II uses the reset to guarantee that register zero actually contains zero and that the line in the icache associated with the reset address is invalidated. To properly test this logic on an FPGA, we initialize the contents of the register file and cache RAMs to non-zero values. So, the upshot of this is that you need to use the reset to get the CPU into a proper state.- Mark as New
--- Quote Start --- originally posted by badomen@Nov 20 2004, 01:12 AM as to your other question, a state machine is different from a processor (althought it's not impossible to make a processor from a state machine, but you'll need to lock yourself in a room for years to achieve this) in that it usually has a finite number of states. they are useful for systems that are not too complicated, but a processor has data stored as variables, so the number of states your processor can have is every combination of values over all memory locations (so lets just call that an infinite state machine).
if you want to see the logic behind a state machine go to the templates in quartus and call up the state machine with the asyn. reset and that may explain the structure to them (a condition to make you change/stay in a state, and an output dependent on the state you are in). --- Quote End --- I mean a state for reading memory, do something with the data (e.g. add, load program counter, start new state machine for microcode, ...), update address (program counter), read from memory, .... My biggest problem after designeing a processor is the toolset (porting a compiler, ...). That's why I use Nios. Stefaan
TO_BE_DONE
If you left that out then the first couple of clocks coming out of the PLL may not be stable (that's what the delay on the reset is for in the reference designs). Your design may work, but I wouldn't trust a circuit on the first clock after being reset from configuration.
Is there a particular reason why people are interested in this?- Mark as New
hello BadOmen,
you said"I wouldn't trust a circuit on the first clock after being reset from configuration. " i.e. the delay designed for the reset from configuration not from the pin PLD_CLEAR_N. is it right?- Mark as New
About the PLL.
You can use the locked output from the pll to and (afterinversion) with the reset pin in the top level, and use this for reset to all modules. Even with no external reset this should (?) work. Stefaan- Mark as New
> reset pin in the top level, and use this for reset to all modules. The locked signal will toggle prior to actual phase lock -- this can cause some problems ;-) I still use a delay (along with the pll lock) to drive reset.- Mark as New
<div class='quotetop'>QUOTE </div>
--- Quote Start --- The locked signal will toggle prior to actual phase lock -- this can cause some problems ;-) I still use a delay (along with the pll lock) to drive reset.[/b] --- Quote End --- This is not what I suspect from a pin named 'locked'. Was an other name better then?- Mark as New
Agreed ... but from the Cyclone Device Handbook: <div class='quotetop'>QUOTE </div> --- Quote Start --- Without any additional circuitry, the locked port may toggle as the PLL begins tracking the reference clock.[/b] --- Quote End --- And ... I did actually observed this behavior -- so the pll locked port by itself is not a good general purpose reset source ;-) Regards, --Scott- Mark as New
Sorry about the delay (just got back from a vacation)
If you want to see in closer detail how a PLL output behaves, make a design with a PLL, and some circuit driven by it and do a simulation looking at the input clock, output clock, and reset signal and you will see why the delay is needed (although I sometimes get lazy and don't bother). When you look at the output from the PLL you'll see the first few output clocks out of phase and this could cause problems internal to the NIOS as it (PLL) locks the phase down. Also thank you for the info about the locking signal not being completely valid to implement the reset (I like some of the others figured it could be used as well).- Mark as New
About the locked signal. If I have to use a delay --> how can I make it in a counter (flip-flops) without any problems then? If you say the clock isn't stable at this point, I suppose I cannot rely on the counter value to be valid in all cases? Also how long must the delay be? Any more information appreciated. (application note??) Stefaan- Mark as New
There's really no substitute for a good external reset ;-) However, I do use the pll locked signal as an enable/clear input to a reset counter that controls reset to a specific logic block. The counter's clock input is an external clock signal, _not_ the output of the pll. And the counter width is set based on the phase lock period from simulation (in my case about 16x the counter's input clock). So, the counter is simply trying to guarantee the stability of the pll locked signal before negating reset. I haven't had any problems ... yet. But to be honest, I'm not particularly comfortable with it either -- my knowledge just doesn't run deep enough at this point 8-( Given the number of posts to this topic -- an application note from the experts would be a welcomed reference.- Mark as New
It doesn't take long for the PLL to lock into phase. Off the top of my head I think the delay in the reference designs is at least two times longer then the PLL locking time so look at the counter value in that one to see what a good value is. The counter should work fine if you use your osciallator and not the PLL output to clock it.
But like what was said before, an external reset is the way to go (just like a bomb with an off switch is a good idea too, lol). Really you are shooting yourself in the foot if you do not have an external reset, you could end up costing you or your company a lot of money if they have to re-spin a board to put one in (and it helps you debug too). Cheers
