12692 Discussions
ERROR:"BINFMT_FLAT: bad magic/rev"
When I run a application program on nios II system,
the sdk shell show :
BINFMT_FLAT: bad magic/rev (0x3000000, need 0x4) BINFMT_FLAT: bad magic/rev (0x3000000, need 0x4)
why?????
The kernel is reporting that the file you're running isn't a valid executable file format. For all Nios II Linux systems, each executable must be in a flat binary format. This usually entails running elf2flt on any applications that you build.
If you'd like I can take a look at the Makefile you're using and try to figure out what's going on. If so, please pm me or post it here in the forum.
if you run a shellscript you get the same error message.
To run shellscripts following option must be compiled into the kernel:
Executable file formats ===> [*] Kernel support for MISC binaries
