ERROR with building uC Linux
Hi
Yes it&#39;s me again http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
Have a problem with the IDE. Have just create a new linux kernel project and have been doing exactly what the quickguide says I should do. BUT when I compile the project it say the following after 10mins of compiling
ERROR: &#39;na_ide_ide&#39; undeclared( first use in this function....
WTF is this??? I have not seen this before. usually it so simple to get it working.
GreateWhite.DK
as the error messge said, na_ide_ide (a compact flash related symbol) is not declared. If you don&#39;t have the compact flash component in your core, disable the support of it in kernel through kernel configuration.
