12746 Discussions
Error creating Project with custom component as reset and exception vector.
GK4
I get the following error when creating a new NIOSII application and BSP from Template with a custom component as reset and exception vector for my NIOS/f cpu. See the attached picture for details.nios_error.png
Where my zim_qspi_controller components interfaces are set generic.
The generics are generated with the _hw.tcl scipt.
In the component the master communicates with a dual port fifo over the avs_mem interface.
--Speicher-Interface avs_mem_write :in std_logic; avs_mem_waitrequest :out std_logic; avs_mem_read :in std_logic; avs_mem_writedata :in std_logic_vector(AVALON_BUS_DATA_BYTES-1 downto 0); avs_mem_readdata :out std_logic_vector(AVALON_BUS_DATA_BYTES-1 downto 0); avs_mem_readdatavalid :out std_logic; avs_mem_byteenable :in std_logic_vector(AVALON_BUS_DATA_BYTES/8-1 downto 0); --avs_mem_irq :out std_logic; avs_mem_burstcount :in std_logic_vector (BURST_BTIS-1 downto 0); avs_mem_address :in std_logic_vector (ADDRESS_BITS-1 downto 0);
I am using:
Platform Designer 18.1 Build 625
NIOSII EDS 18.0.0.v20180425- 1
GK4
After reading this post, I saw that I haven't checked the: isMemoryDevice in the _hw.tcl file.
