I am trying to build the Linux kernel following the quick start-up guide but always getting the following messages: c:/altera/kits/nios2/user.bashrc : No such file or directory ... ... gcc: not found ... etc... (I am using Quartus 4.1, SOPC Builder 4.1 and NiosII release 1.0 on Windows 2000) As I read on another similar topic, I do not get the Microtronix Linux Extensions banner when I start the NiosII sdk shell. I ran the installation repair utilliy from the Linux Distribution install shield but it did not help. Help please! Thanks EricLink Copied
sri,
I had the same problem: just start your SOPC builder Greetings, Hans- Mark as New
sri,
do a search for "Windows NT Patch for Linux on Nios II", download and install the patch ( on any windows flavour, XP included ). It should fix you problem if you start NIOSII IDE from SOPC builder. Cheers JH.
