Hi All .
I want using ethernet on board 1c12 but I can't map pin lan91c111 with board 1c12 . because I don't have manual 1c12 and I can't find it . please help me !Link Copied
--- Quote Start --- originally posted by dai_minh@Nov 13 2006, 04:37 PM hi all .
i want using ethernet on board 1c12 but i can't map pin lan91c111 with board 1c12 . because i don't have manual 1c12 and i can't find it .
please help me !
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=19402)
--- quote end ---
--- Quote End --- what is your board's model name? You can look in the nios2/examples/verilog dir. There are many board designed with lan91c111, you can learn how to connect the lan chip from them.
--- Quote Start --- originally posted by hippo+nov 14 2006, 10:03 am--><div class='quotetop'>quote (hippo @ nov 14 2006, 10:03 am)</div>
--- quote start ---
<!--quotebegin-dai_minh@Nov 13 2006, 04:37 PM hi all .
please help me !
--- quote end ---
--- Quote End --- what is your board's model name? You can look in the nios2/examples/verilog dir. There are many board designed with lan91c111, you can learn how to connect the lan chip from them. <div align='right'><{post_snapback}> (index.php?act=findpost&pid=19424)</div> [/b] --- Quote End --- Hello, for the 1c12 board, you must take morethanIP not lan91c111 ? i think http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/huh.gif
