12612 Discussions
Ethernet transmission speed
My board:DE2-115
My sopc project:webserver(RGMII)(provided by Terasic)
My nios project: simple socket server
Now, I can send some words to my PC from my board by a debugging assistant software.
However, the speed(working on 100Mbps) is faster than the speed working on 1000Mbps.
What I can do to raise the transfer speed?
Why the 1000Mbps is slower than 100Mbps, is it because my debugging assistant software doesn't support 1000Mbps or something else??
What kind of socket are you using? If it is TCP then it is possible that an increase in packet loss due to the higher speed results in a slower effective speed on the socket.
Use a sniffer software such as Wireshark to see if there is any retransmission.
Yeah, as you mentioned, my socket is TCP.
Should I change it to UDP or can I do something to improve the existing situation by changing TCP Socket?
******************my code in NIOS II******************# include <stdio.h># include <string.h># include <ctype.h># include "includes.h"# include "simple_socket_server.h"# include "alt_error_handler.h"# include "ipport.h"# include "tcpport.h"# define MAXDATASIZE 1450
void SSSSimpleSocketServerTask()
int fd_listen;// max_socket
int fd_listen1;
int long bytes_sent;
int long bytes_recv;
int nSendBufSize=SSS_TX_BUF_SIZE;
struct sockaddr_in server_addr;
struct sockaddr_in client_addr;
fd_listen = socket(AF_INET, SOCK_STREAM, 0);
setsockopt(fd_listen,SOL_SOCKET,SO_SNDBUF,(char * )&nSendBufSize,sizeof(int));
if (fd_listen< 0)
alt_NetworkErrorHandler(EXPANDED_DIAGNOSIS_CODE,"[sss_task] Socket creation failed");
else
printf("Socket created");
server_addr.sin_family = AF_INET;
server_addr.sin_port = htons(SSS_PORT);
server_addr.sin_addr.s_addr = INADDR_ANY;
memset(&(server_addr.sin_zero), '\0', 8);
if ((bind(fd_listen,(struct sockaddr *)&server_addr,sizeof(server_addr))) < 0)
alt_NetworkErrorHandler(EXPANDED_DIAGNOSIS_CODE,"[sss_task] Bind failed");
else
printf("Bind is OK\n");
if ((listen(fd_listen,5)) < 0)
alt_NetworkErrorHandler(EXPANDED_DIAGNOSIS_CODE,"[sss_task] Listen failed");
else
printf("Listen is OK\n");
int client_addrlen;
client_addrlen=sizeof(client_addr);
fd_listen1 = accept(fd_listen,(struct sockaddr *)&client_addr,&client_addrlen);
while(1)
if(fd_listen1<0)
alt_NetworkErrorHandler(EXPANDED_DIAGNOSIS_CODE,"[sss_task] Accept creation failed");
else
printf("accepted connection request\n");
fd_listen = fd_listen1;
break;
printf("Server: Sending some test data to client...\n");
char sendbuf[MAXDATASIZE] = "Bjtuxuxu Love FPGA!";
char recvbuf[200] = "Bjtu";
while(1)
bytes_sent = send(fd_listen,sendbuf,SSS_BUF_LEN,0);
if(bytes_sent<0)
alt_NetworkErrorHandler(EXPANDED_DIAGNOSIS_CODE,"[sss_task] Send failed");
else
printf("SERVER : Send is OK \n");
printf("SERVER : Bytes sent:%ld.\n",bytes_sent);
bytes_recv = recv(fd_listen,recvbuf,200,0);
if(bytes_recv<0)
alt_NetworkErrorHandler(EXPANDED_DIAGNOSIS_CODE,"[sss_task] Recv failed");
else
printf("SERVER: recv() is OK.\n");
printf("SERVER: Received data is: \"%s\"\n", recvbuf);
printf("SERVER: Bytes received: %ld.\n", bytes_recv);
return ;
Thanks for your reply.
It depends on your needs. UDP is usually faster and has a lower latency, but you have no guarantee a packet you send will even be received. If you need something safer and need all your data to be transmitted, and retransmitted if necessary, then you should use TCP.
To know what the problem is, you need to analyse the traffic with a sniffer such as Wireshark and see what's wrong.
