External SRAM interface
From the Nios II DK, the two IDT SRAM's (256kB x 16) are set up in 32-bit words. Since our design will only use one SRAM of smaller size (128kB x 16), would I have to import, say a VHDL source, to implement it within SOPC? How can the control signals get tied in with the Avalon bus without having the signals generated as external ports?
Use Interface to userlogic:
Bus Interface Type: Avalon Memory Slave
select add generic list of ports and edit it to
the following.
PORT NAME | Width | Direction | Shared | Type
address | 17 | input | yes | address
write_n | 1 | input | yes | write_n
read_n | 1 | input | yes | read_n
writedata | 16 | inout | yes | data
chipselect_n | 1 | input | --- | chipselect_n
be_n | 2 | input | yes | byteenable_n
timing: I use 2 wait and 1 hold cycle (can be optimized)
Thanks for the instructions. One more question, since the SRAM has lower-byte and upper-byte controls, would both be identified as byteenable_n?
you should get the signals
nnnn_byteenablen[1..0]
where nnnn is the name of your Avalon Tristate Bridge
connect nnnn_byteenablen[0] to \BLE of SRAM
connect nnnn_byteenablen[1] to \BHE of SRAM
Thanks for all your help Fischer. I&#39;m starting to getting the hang of it. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
