Hello Guys,
I need to transmit data to the fpga ethernet network without using uC / OS and uClinux among others! only using code described in nios II, like we do in rs232, there is this possibility? using web edition?Link Copied
Superloop helps you in networking without using any kind of OS.
Thanks for reply!
But, Superloop? how would it work?- Mark as New
--- Quote Start --- Hello Guys, I need to transmit data to the fpga ethernet network without using uC / OS and uClinux among others! only using code described in nios II, like we do in rs232, there is this possibility? using web edition? --- Quote End --- You can download a IP core for free from www.webphyfpga.com (http://www.webphyfpga.com) to do that without a OS or CPU.
Topic Options
