FTP Problems
Hello.
I'm facing some strange problems with my ftp transaction. After a while ( this can be one minute or ten minutes) i cannot transfer anymore files to my board .
The connection is not lost. I'm still able to delete files and change the access rights through the FTP program on my Workstation. Even logging in and out is possible.
I can only solve this transfer problem by restarting uClinux.
Actually i cannot remember such problems, when using a JTAG (nios2-terminal) connection in conjunction with FTP.
On my Workstation I use Windows XP and telnet-client.
On my board I use for Telnet and Ftp the programs in the Microtronix Linux distro.
Has anyone else experienced such problems?
Thank you very much...
maybe you can try to enable some debug messages in ftp.
Or you can try wget/ftpget in busybox.
Hello Hippo,
thank you very much for your ideas. I will get the RFC docs about FTP and try to check this out.
Helmchen
