Failed Executing
Hi all,
I Quartus Web Edition 10.1, I loaded a project nios FPGA. (Terasic DE1)
only with on-chip memory, the run goes well,
When I put the sdram, I get:
Failed Executing: [nios2-download '- = USB-Blaster cable on localhost [USB-0]', - device = 1, - instance = 0, - g, -
An exception stack trace is not available.
Using cable "USB-Blaster [USB-0]", device 1, instance 0x00
Already processor is paused
Reading System ID at address 0x01009878: verified
Initializing CPU cache (if present)
OK
Downloading 00800000 (0%)
Downloading 008051D0 (98%)
Downloading 01004000 (99%)
Downloaded 21KB in 0.3s (70.0KB / s)
Verifying 00800000 (0%)
Between verify failed address 0x800000 and 0x8050DB
Leaving target processor paused
jtag my configuration is:
USB-Blaster [USB-0]
020B30DD EP2C15/20
Node 19104600
Node 0C006E00
Node 00086E00
can anyone help me?
Thank you all.
SDRAM has special clock skew requirements, therefore you can't use the same clock with NIOS. If I remember correctly, the SDRAM clock needs to lead the NIOS clock by 3 ns.
Use a PLL to generate a clock that leads the NIOS clock by 3 ns and use it for the SDRAM.
I did it but still does not work.
Thank you for answer!
