Flash AM29LV065D-90
I am using AM29LV065D-90 flash in a NIOSII V5.0 project that uses a custom board.
My question is since my board has a faster flash, can I use the AM29LV065D-120 instead
of making a custom timing CFI interface? or am I overlooking something?
Thanks in advance for you help!
Just look into the instructions of the user interface when you add it from SOPCBuilder,
it recommends you make one by yourself .
Thank-you!! I will check it out!!
I'm using -120 revision and it works OK.
Hi Brandon,
> can I use the AM29LV065D-120 instead of making a custom
Yes. The cycle time just won't be as fast. Unless your application
is flash-intensive, you probably won't notice the difference.
--Scott
