Flash init from a file
I 'm using the nios IDE.
I want to init the flash with a file which contain a video Frame.
Did someone has an idea to import the data from the file into the memory?
You could use the flash programmer to do so. Select in Nios IDE: Tools->Flash Programer and in the main window check the box: "Program a file into the flash memroy"
Bye,
Luis
thanks, it a very easy and goog solution
