GCC
Dear gurus,
I have the following problem. I have built a library which is compiled and
linked separately from the rest of software. This library is stored in flash
memory as a standalone piece of software. Then I have built an application which
uses this library by calling its functions at some defined flash addresses. The
application has been compiled and linked separately from the library and it
resides at different addresses in flash.
Both the library and the application use global variables. These variables are
allocated at different ram addresses. Since GCC uses global pointer to reference
to global variables, when the application calls a library function, that function
is not able to reference its globals because the global pointer is assigned to the
application's ram area and not to library's ram area.
Can you suggest a way to workaround this problem ? (without suggesting to
rewrite the compiler ...)
Best Regards
/Alessandro
Hi Alessandro,
Disable use of the global pointer with the -G0 compiler option (for both library and app).
If you _must_ use the gp, you can write some fixup code in your library to
save/restore the gp. But, depending on your requirements ... it might not be
worth the effort.
--Scott
--- Quote Start ---
originally posted by alessandro@Feb 28 2006, 07:58 PM
can you suggest a way to workaround this problem ? (without suggesting to
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=12991)
--- quote end ---
--- Quote End ---
Another possible workaround could be that the fixed locations of the functions you have to call in reality contains an assembler stub which only swaps the gp pointer value...
bye
PJ
