Got Stuck while doing NIOS II
Prajwal_RJ
I'm New to this field. i've to make communication interface between the Hardware(FPGA) with Software(GUI). I'm Using Cyclone V FPGA 5CEFA7F27I7. This FPGA does not contain Any Soc in it so we are using, Micron SDRAM(DDR3), NandFlash 16GBx8, DP83867(Ethernet physical Transreceiver) to make the communication with GUI through Ethernet.
Should i have to use NIOS II or Eclipse?
can i able to get some guidelines or easy materials which can be understandable by fresher?
Thank you for the help
Prajwal RJ
EBERLAZARE_I_Intel
We suggest that you start with the Nios V if you're new, and test our design by following our handbook with the OCRAM booting:
https://www.intel.com/content/www/us/en/docs/programmable/726952/23-4/processor-application-executes-in-place-31167.html
Are you also new to Quartus?
EBERLAZARE_I_Intel
Do you have any further questions?
EBERLAZARE_I_Intel
As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 4/5 survey.
