12745 Discussions
HAL API for the Generic Serial Flash Interface FPGA IP, 'altera_safeclib'
meenalkb
In the user guide for the Generic Serial Flash Interface (GSFI) it says "altera_safeclib" must be enabled in the BSP editor to use the HAL API for this device.
With a Quartus 21.1 install and the accompanying NIOS II Software Build Tools for Eclipse I've searched through the BSP Editor UI and can't this setting at all. Also, when I generate the Eclipse BSP from my sopcinfo file, there are no HAL driver files generated for the GSFI.
Does anyone know how I can enable HAL support for this IP?
hareesh
Hi Meenalkb,
To enable the Generic Serial Flash Interface (GSFI) use the HAL API and follow the below steps in Eclipse.
  1. BSP Editor->Nios II
  2. file paths of .sopcinfo and .bsp (new or old) in the open BSP window and click on open.
  3. A platform design window will be open in which you select the BSP software packages option. In that, just enable the altera_safeclib option.
  4. Select Generate BSP.
once the BSP generation is completed. Check in the drivers->inc and drivers->src folders. for
https://www.intel.com/content/www/us/en/docs/programmable/683419/22-1-20-1-1/nios-ii-hal-driver.html
  • intel_generic_serial_flash_interface_top.h
  • intel_generic_serial_flash_interface_top.c
hareesh
Hi Meenalkb,
meenalkb
As you can see, I don't see the altera_safeclib option under Software Packages. What now?
hareesh
can you share screen shot of that ?
meenalkb
I did include a screenshot - perhaps you can't see it. I've attached one now.
hareesh
gsfi ip need enable setting then regenerate sopcinfo then should see altera_safeclib
meenalkb
Hmm tried that.
That makes no difference whatsoever.
hareesh
which version are you using?
meenalkb
hareesh
also tested in Quartus 21.1. That option is available in Quartus 21.1. I think the problem is in software only. It's better to re-install or update the software.
hareesh
can you pls share your platform_design
meenalkb
Hi @hareesh ,
I've attached the .qsys and the .sopcinfo.
I don't know if this is relevant but the IP cores were originally from a Quartus Prime 18.1 design and have been upgraded by the tool to 21.1.
hareesh
Hi, MEENAL BURROWS,
We have tried reproduce the issue with your shared files but we couldn't reproduce it. There no issue in our environment. Attaching a snapshot of project where you can see the option is available in our environment.  we require remote access of your machine to debug this issue further
Thanks & regards,
Hareesh B
meenalkb
Thank you for checking this on your setup Hareesh.
Can we arrange a session to debug this issue on my machine?
meenalkb
@hareesh
Are there special licensing requirements for the Generic Serial Flash Interface IP? I have tried this on a different machine with no luck.
I really only want the source files for information purposes. Would you be able to zip and send these to me via email?
hareesh
Hi meenalkb
you can find IP license details in IP user guide. please find a attachment for project source files.
hareesh
Hi meenalkb,
Since I had provided you the solution and did not received any feedback from you, I shall set this case to close pending. If you still need further assistance, you are welcome reopen this case within 20days or open a new case, some one will be right with you.
I shall set this case to close pending,
If you happened to close this case you will receive a survey. If you think you would rank your support experience less than 10 out of 10, please allow me to correct it before closing or if the problem can’t be corrected, please let me know the cause so that I may improve your future service experience.
Hareesh B.
meenalkb
Hi Hareesh,
Thank you for sharing the source files, that's very helpful.
However, it would really help me to understand why my Quartus 21.1 install is behaving as it is. I requested a remote session in a previous ticket and I'd be happy to go ahead with this if you can arrange it.
Meenal
hareesh
hi
can you please check on another machine.
meenalkb
Hi Hareesh
Yes, I did check on a colleague's machine and had the same problem.
hareesh
did you checked with i shared files?
