/home/zkm/buildroot/toolchain_build_nios2/binutils-2.15/binutils/readelf.c: In function `process_mips_specific':
/home/zkm/buildroot/toolchain_build_nios2/binutils-2.15/binutils/readelf.c:9824: internal error: 段错误 请提交一份完整的错误报告, 如有可能请附上经预处理后的源文件。 具体步骤请参见 <URL:http://bugzilla.redhat.com/bugzilla/>。 The bug is not reproducible, so it is likely a hardware or OS problem. make[4]: *** [readelf.o] 错误 1 make[4]: Leaving directory `/home/zkm/buildroot/toolchain_build_nios2/binutils-2.15-build/binutils' make[3]: *** [all-recursive] 错误 1 make[3]: Leaving directory `/home/zkm/buildroot/toolchain_build_nios2/binutils-2.15-build/binutils' make[2]: *** [all-recursive-am] 错误 2 make[2]: Leaving directory `/home/zkm/buildroot/toolchain_build_nios2/binutils-2.15-build/binutils' make[1]: *** [all-binutils] 错误 2 make[1]: Leaving directory `/home/zkm/buildroot/toolchain_build_nios2/binutils-2.15-build' make: *** [/home/zkm/buildroot/toolchain_build_nios2/binutils-2.15-build/binutils/objdump] 错误 2 ./build: line 51: cd: /home/zkm/buildroot/build_nios2/staging_dir/include/linux: 没有那个文件或目录 rm: 无法删除 “config.h”: 没有那个文件或目录 rm: 无法删除 “autoconf.h”: 没有那个文件或目录 Why ?Link Copied
Please do not post questions here, here is for posting ip.
Please post this question to nios2 uClinux forum. Don't use redhat 9.0 to buildroot, the make command is too old. If you are newbies, please follow the new wiki, do step1-3. http://nioswiki.jot.com/wikihome/operating...ms/%c2%b5clinux (http://nioswiki.jot.com/wikihome/operatingsystems/%c2%b5clinux)
