12687 Discussions
Host based and Read only Zip files
Hi all,
I got a certain code that I need to run having an input file. I download my program to RAM in general and just use the flash for the file when using the "rozipfs".
I tried using once the host based file system and the other time the zip file and I used the performance counter to track a function that does NOT have any access to files in it. I got a difference of 40 million clocks between both results. What's the reason inspite of having no relation to file opening or samples' calling in the meant function ?
And another thing too, in general which is faster the host-based system or the "rozipfs" ? (meaning JTAG or flash memory)
Thanks in advance
Flash/rozipfs will be much faster. Hostfs is going over a GDB link to your PC.
With respect to your other question, I&#39;m not sure why you&#39;re seeing a significant slowdown when using hostfs, however, you&#39;ll never be using hostfs in a real-world embedded system, so I can&#39;t see that it matters much anyway http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
Cheers,
- slacker
Thanks Slacker for ur reply, u are right regarding the real-time operations but still it puzzles me, try me one last time, I will elaborate for a last time http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
My program is as follows:# include "stdio.h"
void filter(int);
int main()
MyClass a;
a.openMyFile("/mnt/rozipfs/aser.txt"); //function that opens a file stream
int data = a.readCurrentInput(); //reads an integer from current data
filter(data); //my function that I want to measure its performance
void filter(int)
int y=data;
/*continue code normally*/
I want to measure the performance of "filter(data)" for zip files and host based files. I get more time in case of ZIP FILE system ! I don&#39;t know the reason.
