12732 Discussions
How NIOS gets reconnection of Simple Socket Server
I am working on Simple Socket Server with Max10 Dev., everything works fine except:
When a connection established, if the client sends a 'q', then the connection can be reconnected again afterward.
But if I closed/or click "disconnection" button(without sending 'q') of my client, then re-connection is not possible anymore.
Could you tell me please how to fix this problem/challenge ?
Thanks in advance!!
Did you disable DHCP?
--- Quote Start ---
--- Quote End ---
Yes, I do disable DHCP.
Do you have any idea about my question?
