12620 Discussions
How can I increase the user memory ?
hi all:
My nios2 board use 16m sdram. but I check the free memory with command "free",I find the total memory = 8796.
# free
total used free shared buffers
Mem: 8796 3072 5724 0 8
Why the user memory so small?
How can I increase the user memory if I do not increase the SDRM capability?
Can I modify kenerl source code or "menuconfig kernel" to increase the user meomory?
Thank a lot!
are you sure that your sdram is 16M?
check the datasheet of your sdram maybe that is 16MBit.
Are you using busybox for shell and services? They will take up a lot of memory when the busybox gets bigger..
You may try the later uClinux-dist approach with SASH and standalone services.
