When multiple instances of the Nios V processor are integrated into a multiprocessor SoC, access to the MHARTID csr register when they execute concurrently is needed to identify the hardware thread.
The Parameters tab of the configuration screen for Nios V in the Platform Designer tool does not allow assigning any value to the MHARTID register.
For Nios II, there is a parameter for manually assigning the CPUID control register value, but for Nios V I do not see a similar parameter.
Then, my question is: how is Nios V's MHARTID csr register assigned a determined value?
Domingo.
Hi
For the MHARTID, this could be set in the platfrom designer under the NiosV IP parameters shown below:
Jingyang, Teh
Thank you for your response.
I am using "Platform Designer 23.1 Build 991 (Quartus Prime Version 23.1std.0 991 11/28/2023 SC Standard Edition)" and these are the options available:
As you can see, there is no parameter for MHARTID.
Which Quartus Prime and Platform Designer versions should I install to allow modifying the MHARTID csr register?
Domingo
I would like to provide additional information. I need to use Quartus Prime Standard Edition because the FPGA device where I am configuring a Nios V/m processor is Cyclone IV. The latest version of Standard Edition for Windows is 23.1.1.
As described in the Nios® V Embedded Processor Design Handbook (Updated for Intel® Quartus® Prime Design Suite: 23.4, date: 2023.12.04), Figure 10 at page 20, the parameter for Nios V/m Microcontroller Intel FPGA IP named "CPU Architecture" has a single option: Enable Pipelining in CPU. The parameter for the MHARTID csr register is not included.
Then I think your previous answer is based on a Quartus Prime 24.x version.
Is that right?
Domingo.
