12748 Discussions
How to Using OpenCores i2c master controller
I inserted the OpenCores i2c Master Controller into my custom board design (NIOS-II CPU) for communicating with an external RTC. Verilog source files were downloaded from the OpenCores website; also a header file named "oc_i2c_master.h". After re-compiling the system library project, in file "system.h" several #define were added.
Questions are:
- How do I write the code for using this controller? Some sample code would be very helpful.
As it's seen, I'm completely new to this topics.
Thanks a lot in advance.
Hi VLorenzo,
I used it and it works.
Give me your e-mail and i'll send you sample file.
bye
my mail id
[venkateshace@gmail.com
please send me I2C RTC(ds1307) verilog code for altera DE2 board.....................
real time clock interface with fpga............
hi,
i also work with DE2 and need to connect ds1307 as part of BSc final project and i have problems.
one of you can send me the vhdl code for this RTC ?
thanks a lot!!
my mail is oriya1992@gmail.com
