12748 Discussions
How to execute NIOS II Command Shell commands from a *.bat file
There is probably a simple solution to this, but I am having a hard time finding it in any of the documentation.
I have four applications that I need to build for a single board. I can build the projects and create the hex files from within the Nios II Command Shell using "make" and "elf2hex". I would like to automate this process. Is there a way to do this with a *.bat file?
John
You can write a myscript.sh file : a shell file with same purpose than DOS batch (*.bat) file.
Have a look at *.sh in nios directories.
You can launch .sh file by (NOT TESTED, it is just an example):
enter the command : sh (or bash) myscript.sh in the good directory
or make it executable by chmod +x myscript.sh and launch it : ./myscript.sh in the good directory.
In this design example zip file under /software you will find a shell script that you can take a look at. If you just want to run a series of shell command then your script should be fairly short. If you edit it on Windows before running it make sure to run dos2unix on the file to make sure it has the correct new line formatting.
http://www.altera.com/support/examples/nios2/exm-modular-scatter-gather-dma.html
I am not quite understanding the process here. I have made a *.sh file and can execute it from the NIOS II Command Shell, thanks for the help there.
How can I run *.sh from windows or a *.bat file?
I did a quick test and this seemed to work. I wrote a one line batch file with this in it:
C:\altera\10.1\nios2eds\"Nios II Command Shell.bat" nios2-terminal
So the Nios II command shell opens and the command "nios2-terminal" is run. So instead of running the terminal you would call your script. So maybe something like this:
C:\altera\10.1\nios2eds\"Nios II Command Shell.bat" sh <path to my_script.sh>/<my_script.sh>
I just tried the following and it just opens the command shell, but doesn't run the script
C:\>"C:\altera\91\nios2eds\Nios II Command Shell.bat
" sh "C:\altera\91\nios2eds\test.sh
Welcome To Altera SOPC Builder
Version 9.1, Built Wed Mar 24 22:13:17 PDT 2010
Welcome to the Nios II Embedded Design Suite
Version 9.1, Built Thu Mar 25 01:25:52 PDT 2010
Example designs can be found in
/cygdrive/c/altera/91/nios2eds/examples
(You may add a startup script: c:/altera/91/nios2eds/user.bashrc)
[NiosII EDS]$
You'll need to use a different drive mapping than you are accustom to on windows. Something like this might work better:
sh /cygdrive/c/altera/91/nios2eds/test.sh
I would start with something simple like putting your script in the default location that the Nios II command shell opens at and then work in the path later once you have that working first. When you add the paths I recommend not putting the script in the ACDS installation directory since it's a good idea to keep your custom stuff separate.
I have tried that too, here is the line straight from the bat file.
"C:\altera\91\nios2eds\Nios II Command Shell.bat" sh /cygdrive/c/altera/91/nios2eds/test.sh
It does not run the script when it opens, but if I type
after the command shell starts, it will run the script.
I am able to run a startup script by copying my script to:
"C:\altera\91\nios2eds\user.bashrc
However I would hate to implement it that way.
Here is my solution/workaround for now anyways.
creatNiosApps.bat
copy "C:\Development\Ethernet_ES\NIOS\test.sh" "C:\altera\91\nios2eds\user.bashrc
test.sh
NIOS_DIR="C:/Development/Ethernet_ES/NIOS"
mkdir $NIOS_DIR"/Hex_Files"
make -C $NIOS_DIR"\software\output_app" clean
make -C $NIOS_DIR"\software\output_app" all
$SOPC_KIT_NIOS2/bin/elf2hex --base=0x41060000 --end=0x41067fff --width=8 --input=$NIOS_DIR"/software/output_app/output_app.elf" --output=$NIOS_DIR"/Hex_Files/output_app.hex"
rm -rf "C:\altera\91\nios2eds\user.bashrc
exit
Thanks for all the help
"sh -c <command> [args]" might work a bit better.
Most "bourne-like" shells behave this way. Since the Nios II shell environment is based on Bash ("Bourne Again SHell"), this should work.
Cheers,
slacker
--- Quote Start ---
creatNiosApps.bat
test.sh
exit
--- Quote End ---
Your quoting is all wrong....
You probably want to include the shell variable substitutions in "" (eg "$NIOS_DIR") not the literal text. This will ensure that any spaces or shell wildcard characters don't generate multiple parameters.
You need to always use forward slashes /, in a shell script \ is a single character escape.
--- Quote Start ---
Cheers,
slacker
--- Quote End ---
You don't need 'sh -c' here, that is usually only needed when you need a shell to do filename globbing or stdin/stdout redirection when a program is running something using one of the exec family of functions - eg execl().
dsl,
I'll admit my knowledge of shell files started yesterday, so I have taken your advice.
slacker,
I tried a few variations of "sh -c <command> [args]" and it does not work, I cannot get the "Nios II Command Shell.bat" to execute arguments when it is started. I am thinking this is a problem with 9.1.
This isn't a problem only with 9.1, as I'm in 11.1sp1 and I can't do it either. Being able to auto-execute .sh scripts from my sim and build environments would help streamline things quite a bit, and reduce the amount of user interaction required.
If ANYONE knows how to automatically run a script at the NIOS shell, it would be greatly greatly appreciated!
The command shell will autorun the script file user.bashrc, so you can use this to make it work.
My batch file and script file are in a previous post. The batch file renames my script file to user.bashrc so it is autorun and starts the command shell. To prevent the script from running every time the command shell is opened, the last thing the script should do is delete itself.
It would be nice if arguments worked, but this method has worked for me.
I do the following:
I put all commands in a shell script, then I execute a wrapper bat file.
alt_win.cmd
@echo off mode con lines=32766 setlocal enabledelayedexpansion SET myPwd=%CD% :: 64-bit / 32-bit OS detection SET binName=bin if "%PROCESSOR_ARCHITECTURE%"=="AMD64" SET binName=bin64 if "%QUARTUS_ROOTDIR%"=="" echo Env Var QUARTUS_ROOTDIR is missing. Is Quatrus installed? Is the path set correctly & exit /b 1 SET QUARTUS_BINDIR=%QUARTUS_ROOTDIR%\%binName% SET PATH=%PATH%;%QUARTUS_BINDIR% for /f "delims=" %%a in ('%SOPC_KIT_NIOS2%\bin\cygpath\cygpath.exe %myPwd%') do @set myCygPwd=%%a ::echo %myCygPwd% %SOPC_KIT_NIOS2%\"Nios II Command Shell.bat" %myCygPwd%/%*
example.bat
@echo off alt_win.cmd %~n0.sh %*
example.sh
# !/usr/bin/env bash --SNIP-- cmd="quartus_pgm -c $uCable -m jtag -o ipv;$binDir/$flashFile" echo " Running \"$cmd\"" $cmd || { echo -e "\e quartus_pgm failed. \e[0m" exitFunc 1 } --SNIP
Using this methods allows you to have a unified interface to Windows and GNU/Linux. Windows users will double click on the example.bat file or even run it from cmd (with parameters and all) and GNU/Linux users will run the example.sh shell script as usual.
Here is a working example : https://bitbucket.org/ftabunimeh/supportboard/src/default/scripts/
